Hifonics XXV-Cyclops repair
Old 27th January 2013, 05:09 PM   #1
Deadly Sones is offline Deadly Sones  Canada
Deadly Sones's Avatar
Default Hifonics XXV-Cyclops repair
So have this cyclops. At first it was constantly going into protect. There was a flash of DC on the output terminals as it would protect. While in protect I got the following measurements:
KA7500BD
Pin 1: 5.78
Pin 2: 2.546
Pin 3: 4.68
Pin 4: 3.983
Pin 5: 1.575
Pin 6: 3.676
Pin 7: 0.00
Pin 8: 12.16
Pin 9: 0.000
Pin 10: 0.000
Pin 11: 12.16
Pin 12: 12.16
Pin 13: 4.97
Pin 14: 4.97
Pin 15: 4.97
Pin 16: 0.000
LM293D
Pin 1: 6.37
Pin 2: 2.483
Pin 3: around 4v (Please see note below)
Pin 4: 0.000
Pin 5: 1.025
Pin 6: 2.944
Pin 7: 0.116
Pin 8: 12.15
Note about pin 3 on LM: It started out around 4v again like the AQ if I held the lead on the pin long enough it would eventually "drain" to below 2v and turn off the protection then relays would click on then voltage jumps back up and go back into protect and turn relays off again.
So after trying this a few times to get readings, I got it to stay out of protect. Using the current limiter. So I rechecked voltages at various locations heres what I have.
KA7500BD -------- -----------------------LM293D
Pin 1: 0.004 -----Pin 16: 0.003 ------- Pin 1: 0.070
Pin 2: 2.163 -----Pin 15: 4.470 -------Pin 2: 2.271
Pin 3: 0.075 -----Pin 14: 4.470 -------Pin 3: 1.800
Pin 4: 0.075 -----Pin 13: 4.470 -------Pin 4: 0.003
Pin 5: 1.372 ---- Pin 12: 5.45 ---------Pin 5: 0.945
Pin 6: 3.103 -----Pin 11: 5.45 ---------Pin 6: 2.710
Pin 7: 0.003 -----Pin 10: 1.785 ---- ---Pin 7: 0.070
Pin 8: 5.420 -----Pin 9: 1.782 ----- --- Pin 8: 5.46
IRFP064N: Leg 1: 1.6v ......Leg 2: 8.2v ................................Leg 3: 0.000v
Rectifiers: Leg 1: 68.5v ......Leg 2: pulses display of dmm .. Leg 3: 68.7v
IFRP360LC: Leg 1: 50v .....Leg 2: 68.5v ..............................Leg 3: 51v
I have the following readings on the output drive card pins:
Pin 1: -51.0v ...............Pin 8: 1.846 .............Pin 15: -68.6
Pin 2: -51.2v .............. Pin 9: 5.03 .............. Pin 16: -68.2
Pin 3: -68.5v .............. Pin 10: -5.42 ...........Pin 17: -68.6
Pin 4: -58.7v ...............Pin 11: 0.000 ..........Pin 18: -58.7
Pin 5: -68.6v ...............Pin 12: -5.10 ..........Pin 19: -68.6
Pin 6: -68.1v ...............Pin 13: 5.00 ...........Pin 20: -51.4
Pin 7: -68.6v ...............Pin 14: 8.73 ...........Pin 21: -51.3
...and there is over 40vdc on the output speaker terminals when relays are engaged.
Now after leaving my resistor cool, and recharging my battery. I can't get it to stay out of protect again. Back to point one.
This pic shows a spot on the PS driver card thats not looking too good or was repaired before and not cleaned up well.
Old 27th January 2013, 07:54 PM   #2
K, I should prob mention that there is no protection light staying on. The top lights are on but no clip or protect. It blinks green then goes out completely.
I went over both the PS and output transistors and they seem OK in the circuit but having DC on the out terminals I'm doubting it...
Old 27th January 2013, 07:59 PM   #3
timwebb is offline timwebb  United States
any leaking or bad output drivers of fets? with 40dc coming out. i would check those irfp360s.
Old 29th January 2013, 12:55 AM   #4
Perry Babin is offline Perry Babin  United States
Do you ever see rail-rail oscillation on the output transistors?
Old 29th January 2013, 06:19 PM   #5
... how would I check for that? ....
Old 29th January 2013, 06:50 PM   #6
I don't know the exact configuration of the output stage but you should have a square wave that swings from one supply rail to the other on either the center or 3rd leg for all output transistors. You need to touch your scope to the legs and monitor the display from the time that you apply remote voltage. Set the scope to 20v/div and 2ms. If you see something that looks like a wide trace, set the time base to about 5us and see if there is a clean sine wave.
Old 29th January 2013, 07:37 PM   #7
Should I be driving a signal into it for this test?
I'm not sure if there is or not... As soon as I touch the red prob to either pin the trace darts up off the screen. even if I set it to 50v/div. I tried black on both the center tap and batt ground terminal.
With the power applied (no remote) the DMM shows 0.040v on pins 1 & 3 and pin 2 as a slowly draining rail. Almost down to 1.5v now....
With remote applied using DMM I have -58.9v on pins 1 & 3 and 66.8v on pin 2. of 2 banks and -66.4v on pins 1&3 and -60v on pin 2 of the other 2 banks.
My settings:
Old 29th January 2013, 07:48 PM   #8
There shouldn't be enough voltage to deflect the trace to beyond the top/bottom of the display at 50v/div. Are you sure that you have a 10:1 probe and that you're using the correct part of the dial?
Old 29th January 2013, 07:49 PM   #9
oops it was on 1x ... lets try this again
Old 29th January 2013, 07:51 PM   #10
No no oscillation... just jumps to voltage an looks a little "noisy" (slight wavy)
Hifonics XXV-Cyclops repairHide this!Advertise here!
Hifonics XX-Cyclops brandes.cm Car Audio 20 20th July 2014 09:18 PM
Exposure XXV noise problem richardtheboffin Solid State 0 22nd February 2012 10:57 PM
Need output driver card info for Hifonics Cyclops Deadly Sones Car Audio 2 19th October 2011 10:29 PM
Hifonics BXI608 repair greg_gorrell Car Audio 18 1st April 2010 02:12 PM
Hifonics BXI608 repair greg_gorrell Class D 0 17th March 2010 05:02 AM
