#11 |
It is turning on everytime without clicking back off now, no protection lights, but no oscillation and 60v dc on output terminals. It pulling about 3.0amps with the limiter in place
#12 |
What happened to the 40v of DC on the speaker terminals? That should have deflected the trace by nearly 1 full division.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 |
thats what I meant... 60vdc in the speaker terminals... it might have been that high from the start
#14 |
First pic is reading with prob on center leg of output transistor.
Second pic is reading with prob on 3rd leg Third pic is probe on + speaker termial 4th pick is with probe on - speaker terminal |
#15 |
I have to go grab my son... I'll be back soon, thanks as always Perry.
#16 |
Which audio driver board is this amp using?
#17 |
DMW3640NHV-v30
#18 |
If you've confirmed that all outputs are OK and none have broken legs, post the DC voltage on all terminals of the driver board. Place the black probe on the negative speaker terminal.
#19 |
I don't see any broken legs and they all test OK in the circuit. I haven't removed them to test... there are no shorts and they all pretty much read the same.
I have the following voltages on the output driver card pins. 1: -60v 2: -60v 3: -64v 4: -54.6v 5: -63.7v 6: -63.1 7: -63.5 8: 1.335 9: 5.03 10: -5.31 11: 0.000 12: -5.10 13: 5.0 14: 7.267 15: -63.5 16: -63.1 17: -63.5 18: -54.4 19: -63.6 20: -60.1 21: -60.2 Should I pull it out of the case and remove the outputs and test out of the circuit? Last edited by Deadly Sones; 29th January 2013 at 09:41 PM. |
#20 |
I think pin 14 should be at 15v. Check the regulator feeding it.
| Hifonics XX-Cyclops | brandes.cm | Car Audio | 19 | 1st April 2013 02:35 PM |
| Exposure XXV noise problem | richardtheboffin | Solid State | 0 | 22nd February 2012 10:57 PM |
| Need output driver card info for Hifonics Cyclops | Deadly Sones | Car Audio | 2 | 19th October 2011 10:29 PM |
| Hifonics BXI608 repair | greg_gorrell | Car Audio | 18 | 1st April 2010 02:12 PM |
| Hifonics BXI608 repair | greg_gorrell | Class D | 0 | 17th March 2010 05:02 AM |
