Hifonics ZEUZ ZX4000 - SO NEED service manual or schematic!
Old 24th January 2013, 07:49 AM   #11
lexxm6 is offline lexxm6  Russian Federation
I think problem in voltage amplifier.
I have 15 mV on resistors (4.7 Ohm) in base all output transistors and in one channel I have not voltage on resistor (220 Ohm) between shoulders ("+" and "-"), but in other channel I have 18 mV on same resistor.
And... is it not very low "Ibe" in bases? It is 0.15/4.7=0.032mA...
Old 25th January 2013, 03:33 AM   #12
Solved the problem with the noise.
It was in bad solding jumper between the amplifier output voltage and one of the output stage transistor.
But I have another problem. I need to set the quiescent current of 60 mA.
But I can not find this resistor without diagram
Can you tell where it should be?
As I understand it at the amplifier input voltage...
Sorry for calculate. True is: 0.015 v/4.7 ohm=0.0032 A, so Ibe=3.2 mA ... it is really near Class B.
Transistors are cold. It is to bad for sound. I need Ibe = 60 mA.
Old 26th January 2013, 09:48 AM   #13
So, I measured the AC voltage at the output emitter resistor, it is without IN signal at 0.5mV. Resistor 0.1 ohm / 5W. Emitter current only 4.5 mA, which is very small and tranistory work practically in a class B.
I can not find resistors adjust the quiescent current.
Help me find them, please!
Old 29th January 2013, 01:33 AM   #14
Perry Babin is offline Perry Babin  United States
Where did you get the bias current of 60ma?
You measure the DC voltage across the emitter resistors, not the AC voltage.
Most amps without bias pots are class B amps.
Old 29th January 2013, 05:09 AM   #15
Sorry, yes, DC and yes - Class B.
Actually I found current regulator resistor.
But try to set 60 mA yet...
Old 30th January 2013, 05:08 AM   #16
Schematic still searching!
Hifonics ZEUZ ZX4000 - SO NEED service manual or schematic!Hide this!Advertise here!
Hifonics Service manual / schematic camusmuse Car Audio 69 22nd January 2013 10:19 PM
Looking for NADC320 service manual / schematic huangyong Solid State 1 10th August 2009 02:30 PM
Nakamichi service manual/schematic gain wire Analogue Source 0 23rd March 2009 01:53 AM
DCD1800 service manual / schematic tritosine Digital Source 2 22nd February 2009 04:49 PM
pm78 schematic or service manual Luke Solid State 20 18th March 2006 02:20 AM
Copyright ©1999-2017 diyAudio
