Rockford Fosgate T20001BD wont power up
Rockford fosgate T20001BD
Heay Perry I knew you would be the first to answer Thanks!!
Pin 1: .42
Pin 2: .137
Pin 3: .045
Pin 4: .006
Pin 5: .700
Pin 6: .000
Pin 7: .000
Pin 8: .006
Pin 9: 3.58
Pin 10: 1.921
Pin 11: .001
Pin 12: .667
Pin 13: .001
Pin 14: 10.36
Pin 15: .000
Pin 16: .001
Pin 17: 13.34
Pin 18: 4.98
OK I went and got a 1 ohm resistor and installed it and the amp powered up and played fine but r35 and r36 gets real hot You cant touch them and the amp was only on 2 or 3 min. what should I check now? THANKS Perry for all your help!!
