Go Back   Home > Forums > General Interest > Car Audio
Old 21st January 2013, 09:38 PM   #1
Default Rockford fosgate drop in voltage source 10001bd
Hello, this is my first post, excuse my English I'm using a translator, I have a Rockford Fosgate 10001bd, Avia and been repaired previously, the problem is that it has low power output, to revise note that gives a voltage + - 32 vols, Bone 64 total volts with multimeter diodes in central legs, but the volume up with speakers connected the voltage drops to 50% with distortion, I'm testing with a battery of 900 cold cranking amps and 11.5 volts lose, nothing warms out than normal, any idea where I can start looking? Thanks in advance for your time, greetings from Mexico.
Old 22nd January 2013, 05:51 AM   #2
seankane's Avatar
11.5 volts is a little low to be testing that amp. What is the voltage across the red and black wires?
Red probe on red wire and black probe on black wire.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 22nd January 2013, 09:26 PM   #3
hello, my battery brand 12.4 volts, but by working the amplifier to a load of 1 ohm multimeter drops to 11.5 volts to operate and amplficador 4 awg wiring, so the voltage supply (battery) do not think is the problem, I would assume that the driver of the power supply is not keeping the load voltage, since in reality there is little output power of + -32 volts, volts drops to +-12 ; consumption amplifier is 2 amps idling about, any ideas? I follow the slope
Old 22nd January 2013, 10:04 PM   #4
I agree. You need to test this with a supply that can keep the voltage above 13v. If you're reading 11.5, it's actually lower than that.
If you have 64v between the center legs of the rectifiers, it's actually ±64v with this amp.
Old 22nd January 2013, 10:31 PM   #5
hi perry, test in car with engine running and the same results, new battery, 13.5 volts of power amplifier only sends 64 volts between central legs of the rectifiers. and driving lanes + -32 volts, by increasing the volume in Hu, voltage decrease dramatically, up to 30 volts, and in lanes drops to ± 12 volts, the battery remains new minimum 12.5 volts.
Old 22nd January 2013, 10:52 PM   #6
Measure the voltage across the screws for the on-board fuse. What is the maximum voltage you read when the amp is loaded?
Old 22nd January 2013, 11:36 PM   #7
connecting fuse multimeter red probe and black probe to central leg rectifiers brand me +50 volts and -23 volts
connecting multimeter black probe negative conectos red tube rectifiers central leg brand me +38 volts and -36 volts
amplifier check in ralenti
Old 23rd January 2013, 12:55 AM   #8
I think there is a communication problem.
Try this.
On Q5 with the black probe on leg 3 and the red probe on leg 1, what is the DC voltage when the amp is loaded?
When it's unloaded?
Do the same with the black probe on leg 3 and the red on probe on leg 2. Post the voltages.
Old 24th January 2013, 10:17 PM   #9
El Q5 con la sonda negro en la pierna de 3 y la sonda roja en la pata 1, el voltaje de CC cuando el amplificador está cargado: es 4,52 voltios
Cuando se ha descargado? es 5,082 voltios
lo mismo con la sonda negro en la pierna de 3 y la sonda roja en la pierna 2.
descargada: 14,0 voltios
cargados: 13,2 voltios
conectado a 2 ohms
* placa madre modelo pc5445
Old 24th January 2013, 11:30 PM   #10
perry, power supply use trans irfc60? is the problem, and resistor of 39 ohms
Rockford Fosgate 225.2 S Merlington Car Audio 1 11th November 2012 11:28 PM
Rockford Fosgate P10002 rafi77 Car Audio 40 25th June 2012 03:50 AM
Rockford Fosgate P5002 Rail Voltage on Output FET Gates maddhaggis Car Audio 10 16th January 2012 03:30 PM
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
