Precision Power 2150AM
Would the Z48's work or would the Z44's be a better choice??
If either will work what do i need to change the gate resistors to ??
Also do you happen to have a high res pic of the board (power supply fet section) ??
right behind the power and ground wires the board is marked C29 but only has 1 thru hole to i dont know what goes there
I only have photos of the 2150M.
The Z44s with 100 ohm gate resistors will be better than the originals. If you use the Z48s, use something like a 68 or 75 ohm resistor.
