Clarion DPX1000.2
Clarion DPX1000.2
Old 20th January 2013, 12:42 AM   #1
S Merlington is offline S Merlington  United States
Default Clarion DPX1000.2
Amp powers up and idles perfectly..
I have both + - 15 volts on the op-amps..
Amp produces both + - 47 volts of rail..
Amp has no output..
Any ideas??
Old 20th January 2013, 02:17 AM   #2
seankane is offline seankane  United States
seankane's Avatar
Does it use a relay to engage audio to the output terminals?
Can you post up a pic of the board?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 20th January 2013, 02:21 AM   #3
No relay in this amp But it uses the Tripath board..
I will try to get a pic up in a lil bit
Old 20th January 2013, 02:23 AM   #4
Perry Babin is offline Perry Babin  United States
R46 commonly opened or came unsoldered.
Old 20th January 2013, 02:33 AM   #5
R46 Measures 3.4 ohms out of the board..
I cleaned both sets of pads and soldered the resistor back in from the top and bottom sides..
Still no output..
Old 20th January 2013, 02:46 AM   #6
It's possible that the module has failed.
I think that the resistor is supposed to be a 1.1 ohm. I don't know if the difference in resistance will prevent it from producing audio.
Old 20th January 2013, 02:49 AM   #7
I i measure directly across the resistor i get 0 volts...
If i place the black probe on the ground termianl and measure 1 side at a time i get -47.1 volts..
I also get -47.1 volts on Pin 19 of the Tripath chip..
Is that voltge correct or should it be near 12 volts?
Old 20th January 2013, 02:55 AM   #8
I think it should be 12v above the negative rail.
Old 20th January 2013, 02:59 AM   #9
Guess i will trace the circuit back and see what i can find
If all tests good and the Chip is defective the amp is unrepaiable ?
Old 20th January 2013, 03:03 AM   #10
The ICs have been difficult to find in the past but I haven't looked for any in a few years.
Clarion DPX1000.2Hide this!Advertise here!
clarion apx4240 DREW028 Car Audio 3 15th April 2012 01:29 AM
clarion dxp11551 timwebb Car Audio 2 22nd May 2011 05:36 PM
Clarion DPX11500 m4ick Car Audio 1 12th April 2011 03:37 PM
Need Help with Clarion Deck...PLEASE.... fredrow Car Audio 14 9th March 2009 11:36 PM
Clarion nbcd Car Audio 1 8th August 2005 05:27 PM
