mrp m1000
mrp m1000
Old 18th January 2013, 03:01 AM   #1
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Default mrp m1000
This amp had 2 bad output transistors. I pulled them out and it seemed to power on fine. Installed replacements and the blue light had a slight plus. Pulled q4006 and q4005 and everything seems ok ( no more plus) . Currently ALL outputs are not installed.
Old 19th January 2013, 09:15 AM   #2
seankane is offline seankane  United States
seankane's Avatar
What is your question?
Did you resolve this repair?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 19th January 2013, 06:09 PM   #3
Since the outputs are removed will my reading from the output drivers be true?
Old 19th January 2013, 07:34 PM   #4
seankane's Avatar
If your only dealing with a couple parts, to get an accurate reading remove them from the circuit to test for leaky or shorted drivers.
Old 9th December 2013, 12:14 AM   #5
Does any one have a repair manual for this a amp?
Old 9th December 2013, 02:49 AM   #6
Perry Babin is offline Perry Babin  United States
Email me
babin_perry@yahoo.com
Old 9th December 2013, 05:39 AM   #7
Do you know a Irf3414 replacment? I can't even find a data sheet. These are on board locations q4005-q4008.
Old 9th December 2013, 05:50 AM   #8
3415, not 3414.
http://octopart.com/partsearch#!?q=irf3415
Old 23rd December 2013, 05:25 PM   #9
I got the amp to play now but when I raise the gain it cuts off. I dont hear my power supply buzz as if its under a heavy load.
I replaced all outputs and ic9802. Im not 100% ic9802 was bad. I replaced it a few months ago and can not remember the circumstances.
Old 6th January 2014, 06:04 AM   #10
ive been probing around and in the pop kill circuit q4501 the base gets a reading of 61mv with no input connected. when I do connect a source and increase the volume it increases to 70mv and cuts off.
Any ideas where to check?
mrp m1000Hide this!Advertise here!
alpine mrp-m1000 mike49504 Car Audio 47 17th June 2013 12:48 PM
No output from MRP-M1000 BlackCivicHatch Car Audio 25 26th January 2013 11:33 PM
Alpine MRP-M1000 mike49504 Car Audio 20 4th June 2011 04:37 AM
Alpine MRP-M1000 mike49504 Car Audio 7 30th January 2011 10:57 PM
Alpine MRP-M1000 argonrepublic Car Audio 2 11th August 2009 03:28 PM
