Go Back   Home > Forums > General Interest > Car Audio
Old 15th January 2013, 02:20 AM   #11
email me if you want the schematic
brandes.cm@gmail.com
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 15th January 2013, 02:56 AM   #12
Pin 1 of the KIA7500 is driven from IC2 pin 1 or 7 on the power supply pwm board.
D206 is the protect line from the output card, goes to pin 11 of the power supply pwm board. What voltage do you have on either side of D206?
If you lift D206 it may keep it from protecting, but use caution when doing this. Limit current and watch the current as you power it up.
Old 15th January 2013, 09:23 AM   #13
Deadly Sones's Avatar
Thank you brandes, I'm pretty sure Perry gave me a schematic a lil while ago. I'll have to find where I put it.
I have roughly 2.500 on the cathode side of D206 and it keep falling to 2.450 then jumps back to 2.5 and starts to fall again. I have 0.000v on the anode side.
I'll get more into this after work tonight
Old 19th January 2013, 01:45 AM   #14
I have the following voltages on IC2 (IL393):
Pin 1: 6.62v
Pin 2: 2.473v
Pin 3: 2.53v
Pin 4: 0.000v
Pin 5: 1.025v
Pin 6: 3.23v
Pin 7: 0.116v
Pin 8: 12.67v
There is nothing on any pin of the LM293 (U1) on the output card. There is no voltage on any of the cards pins.
Old 19th January 2013, 05:48 AM   #15
Do you see a pulse of DC on the output filter inductors when you power the amp up?
Old 19th January 2013, 10:00 AM   #16
Yes, I do... for just a split second, or one pulse yes. Then it reads 0.000. Both inductors have readings of just under .200v (using DMM) before it goes into protect. Which is almost instantaneously.
Old 19th January 2013, 04:14 PM   #17
Q7, 11, 19 and 22 commonly fail on these boards. Do you think that it's possible that one has failed and it's simply a coincidence that it failed when he was testing the speakers?
Why was he popping the speakers? Was he possibly already having trouble with the amplifier.
You stated that the amp was connected but didn't say that it was on so I'm assuming that it was not on. If that's true, the amplifier circuit would not have been connected to the speaker wires because the relay would not have been closed.
Old 20th January 2013, 09:24 AM   #18
I guess anything is possibly when it comes to this stuff Perry. They pop speakers when you run 8ga speaker wire thats all the same color and have multiple coils and speakers to make sure they have the right speaker and proper polarity. Some vehicles are just a wad of wire ends to work with.
I'm not sure if radio (amp) was on or not. He just said it worked in the morning and didn't work after he was done wiring the subs.
I checked Q7, 11, 19 & 22 with my DMM. All pin configurations have high resistance and checking them on the board in diode check they appear fine. There is however no voltage on any pin with power applied (I assume cause of protect).
Can I lift D206 and see what happens? I do have a 50watt 2 ohm resistor to limit current. The amp is still in the case.
This amp is driving me nuts... , lol
Old 20th January 2013, 11:53 AM   #19
Not sure if it means anything but I noticed as soon as I apply remote the protect light comes on. Then it turns off for a second and the power light flashes and then back to protect. It does this twice before the protect light stays on. So basically it tries 2 twice to turn on. dunno...
Old 20th January 2013, 01:33 PM   #20
One thing I'm not understanding...
The output driver card only has like .003 - .005v on pins 1-1 to 1-7 & 3-1 to 3-7. On pin 2-1 I have 4.24v the same as the cathode on D206 (protection circuit). The other 7 pins 2-2 to 2-8 are 0.000v. Now is the voltage coming from pin 11 of the PS card? or is it going to it? I thought it was in "input" for the comparator on the PS card, so it would have to be outputted from the output card?
What drives the output card? The 12v regulated voltage that I don't have? how is this 4.2v being created? Looks like I have 12.7v up to R4A then after the zenner and diode I have 4.2 at point R29B. Then it goes into the comparator input.
One of the other comparator input is TH1. It has resistance, so I think its fine.
I'm lost...
FS : Antique Sound Labs AQ-1003 PCB for DIY (INTEGRATED AMP EL34 PP) ANALOG GUY Swap Meet 7 21st April 2012 12:23 AM
ASL AQ 1002 PP KT88 problem with input stage limono Tubes / Valves 1 23rd February 2011 05:46 PM
AQ -1200 mike49504 Car Audio 44 30th September 2010 12:57 AM
2200 uf 6.3 v Black gate for 2200 uf 16 vdc max29 Analog Line Level 7 7th November 2007 08:51 AM
Antique SoundLab AQ-1003 cfamily Car Audio 1 15th July 2006 02:27 AM
Copyright ©1999-2013 diyAudio
