Go Back   Home > Forums > General Interest > Car Audio
Old 14th January 2013, 09:43 AM   #21
seankane's Avatar
So I wonder why the -1.736 vdc across when their is only suppose to be .5vdc?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 14th January 2013, 09:44 AM   #22
The 0.5v is for the resistors.
Old 14th January 2013, 09:51 AM   #23
I looked up the datasheet for the LEDs and 1.7 isn't far from spec. I don't guess that I'd be concerned. The service manual is probably wrong. It certainly wouldn't be the first time.
If you ever replace an LED in a circuit where the forward voltage is critical, you need to used a replacement that has the same forward voltage as the original. It wasn't an issue here but it is when the forward voltage is used as a reference.
Old 14th January 2013, 09:57 AM   #24
seankane's Avatar
With no audio on pin 2 of IC106 do you think the IC could be defective?
There is supply voltage on pins 1 and 9 if I remember right but nothing on any of the other pins.
If the phase switch was defective could that cause the channels to take turns being dead when switched?
Old 14th January 2013, 10:07 AM   #25
Why not just check the switches?
Old 14th January 2013, 10:09 AM   #26
seankane's Avatar
I am going to just have to remove all 6 of them.
Old 14th January 2013, 10:10 AM   #27
Why do you have to remove them?
You only need to check the three that I listed.
Old 14th January 2013, 10:12 AM   #28
seankane's Avatar
I was under the assumption they had to be removed to test them.
Old 14th January 2013, 10:12 AM   #29
email me.
babin_perry@yahoo.com
Old 18th January 2013, 06:54 AM   #30
seankane's Avatar
I took the phase switch apart and cleaned it, then assebled it back on the board.
The amp produces clean audio on both channels and works great.
Would anyone know where to get a 3 position 12 pin pcb mount switch for this amp?
I would like to replace it with a new one.
Alpine MRV-1002 m4ick Car Audio 8 22nd February 2012 08:40 PM
Alpine MRV T500 mk2singh Car Audio 0 11th December 2010 10:47 AM
Alpine MRV-F401 or MRV-F400 Service Manual M.André Car Audio 6 21st February 2010 09:37 PM
alpine mrv-1000 kgkroman Car Audio 1 4th December 2009 01:46 PM
alpine mrv 1505 IMPALAMAN1 Car Audio 107 9th September 2009 08:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
