Alpine MRV-1505 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 14th January 2013, 05:44 AM   #11
seankane's Avatar
OK not sure if it matters but one was out when I got the amp and I replaced all the outputs and now they are both lit.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 14th January 2013, 06:02 AM   #12
The voltage across the LED may be important. Measure the DC voltage across the terminals of both LEDs to confirm that they are not significantly different.
Old 14th January 2013, 07:41 AM   #13
seankane's Avatar
They are both identical sitting at -1.736 vdc.
Old 14th January 2013, 07:51 AM   #14
Measure across the terminals of each LED.
Old 14th January 2013, 07:56 AM   #15
seankane's Avatar
I did.
Old 14th January 2013, 08:10 AM   #16
Did you replace both of them?
Old 14th January 2013, 08:28 AM   #17
seankane's Avatar
Both of them as in the LED'S?
I replaced the outputs in this amp and thats all so far.
Old 14th January 2013, 10:01 AM   #18
If you still have the originals, I'd suggest reinstalling the good one to see what the voltage was across it. According to the service manual, Rx48 and Rx52 shouldn't have more than about 0.5v across them. With the LEDs you used, I'd expect that it is significantly more.
Old 14th January 2013, 10:05 AM   #19
seankane's Avatar
I didnt replace the LED'S I only replaced the outputs in this amp.
Everything else is exactly how it came to me. In a previous post I metioned that one was out when I received the amp. I replaced the outputs in the amp and then they were both lit.
The amp has the original LED'S still installed.
Old 14th January 2013, 10:41 AM   #20
I misread post #10.
Alpine MRV-1002 m4ick Car Audio 8 22nd February 2012 09:40 PM
Alpine MRV T500 mk2singh Car Audio 0 11th December 2010 11:47 AM
Alpine MRV-F401 or MRV-F400 Service Manual M.André Car Audio 6 21st February 2010 10:37 PM
alpine mrv-1000 kgkroman Car Audio 1 4th December 2009 02:46 PM
alpine mrv 1505 IMPALAMAN1 Car Audio 107 9th September 2009 09:02 AM
Copyright ©1999-2017 diyAudio
