Hifonics HFI 1000d
Hifonics HFI 1000d
Old 12th January 2013, 04:34 PM   #1
brandes.cm is offline brandes.cm  United States
Default Hifonics HFI 1000d
Are all the outputs IRF640n's?
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 12th January 2013, 04:41 PM   #2
timwebb is offline timwebb  United States
if i remember right they are. i got a brz1200. it uses all 640's
Old 12th January 2013, 06:57 PM   #3
seankane is offline seankane  United States
seankane's Avatar
I have a BXi2006D that uses all IRF640N's. Some of their amps do and some use the 640/9640 combo.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 12th January 2013, 09:02 PM   #4
Precisely why I asked about that specific amp.
Old 12th January 2013, 09:08 PM   #5
seankane's Avatar
Post a pic of the board.
If the amp used "N" channel outputs only would you be able to tell by looking at the audio driver boards drivers?
Old 12th January 2013, 10:57 PM   #6
It will oscillate fine if I remove one of the output inductors. It doesn't matter which one.
Old 12th January 2013, 11:25 PM   #7
seankane's Avatar
If memory serves you should have oscillation on one side of the output inductor and audio on the other side with them installed.
Old 12th January 2013, 11:50 PM   #8
With both installed I get excessive current draw. If I pull the final inductor making up the last filter it will idle fine, but I see no audio.
Total mental lapse on this one.....
Old 12th January 2013, 11:53 PM   #9
Perry Babin is offline Perry Babin  United States
Do you see audio on the output side of the other filter inductors?
Can you post a photo of the board?
Old 12th January 2013, 11:58 PM   #10
seankane's Avatar
Well if you have no audio at one terminal of the inductor you may have an audio driver board issue.
Hifonics HFI 1000dHide this!Advertise here!
1000D Memphis Amp ? Hoppy72450 Car Audio 11 22nd December 2017 10:25 AM
memphis 1000d timwebb Car Audio 36 28th August 2011 11:30 PM
Hifonics HFI 1500D mike49504 Car Audio 4 25th July 2011 05:35 AM
another memphis 1000d timwebb Car Audio 3 11th April 2011 03:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 03:32 PM
