Rockford Fosgate Power 650
Old 6th February 2013, 07:29 AM   #81
seankane is offline seankane  United States
seankane's Avatar
The bias is set as it should be on the other channels.
Scope setting was 2ms/2vd
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 6th February 2013, 08:52 AM   #82
seankane's Avatar
I figured it out.
I should have known, when all I did is reflow some solder to cold joints and the channel had distorted audio.
The solder followed the legs of the D41D8 transistor to the top side of the board and made a solder bridge between the base and collector.
The bridge was not visible because it was under the transistor and it was a very tiny bridge.
The amp works awesome.
Thanks Perry.
Old 6th February 2013, 09:38 AM   #83
seankane's Avatar
Please read #81 and #82.
The amp ran hard on the bench for about an hour, fan works great, amp sounds awesome. No issues. Bias is holding.
Most of the time the answer to your own question is right in front of you, you just have to look for it.
Thanks again Perry.
Rockford Fosgate Power 650Hide this!Advertise here!
Rockford Fosgate Power 650 Mosfet "rejuvification" pgerry Car Audio 16 20th October 2012 02:25 PM
Rockford Power 650 Mosfet seankane Car Audio 16 7th September 2011 07:17 PM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
rockford fosgate power 650 mosfet mike49504 Car Audio 43 24th March 2011 10:21 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 08:11 PM
