Over the weekend I put in a car stereo to my 1994 Oldsmobile Cutlass Cierra S. I am using custom everything, including power supply, speaker wire, grounding, crossovers, etc. I have a Nakamichi MB-100 stero system, a 200 watt alpine V-power MRP-F200 amp powering the 4 speakers (front and back), with the power and remote turn on cable jumping over to a jenson 600 watt XA-4250 amp bridged (that I got used at the flea market). The jenson is powering a 10 inch pioneer sub.The speakers are MB quartz with titanium tweeters and mid range built in. The corssovers in the front are factory mb quartz and in the back are Boston. The amps are grounded to the chassy of the trunk.
When all is said and done, the radio turns on in the dash and the amps light up in the back, but I get no sound from any of the speakers or the sub. I have only tried radio, as the cd player is jammed and I do not have an aux cord (i just ordered one and it should be here soon). Should'nt I at least be getting some static or something from the radio? Let me know if I need to provide any more info. Thanks, Greg |
#2 |
If you unplug the RCAs from the head unit and touch the center conductor of the RCA cable going to your amps, do you hear any noise?
If you set the volume high on the head unit, do you read any AC voltage from the RCAs on the head unit?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 | |
That said, no I got no sound by touching them with my hands. I tried putting my friend's tone maker device on the RCA cable at the front and got no sound. I was going to try going to walmart and getting an AV to headphones adapter and plugging it diretly in to the amp to see if I get any sound. I do not presently have a voltage meter. I could maybe borrow one up at the auto parts store. If I have the speakers only plugged in to one amp, and the sub plugged soley in to another amp, if only one of the amps is blown should i get sound out of one of the two? The second amp's RCA is bridged from the pre-amp out from amp 1. |
#4 |
tl;dr of above post is no sound by touching rca's. I wanted to know if I would get sound from somewhere if only one of the amps was blown.
#5 |
Plug the RCA cables directly into the inputs of each amp when testing.
#6 |
#7 |
Didn't you have the RCAs going from one amp to the other?
If so and the first amp is defective, the second one wouldn't get any signal.
#8 | |
Also, I'm sure this is bad, but I unplugged the RCA going to the first amp from the head and when they touched metal I got a little spark, so I'm pretty sure they have juice coming through them. I also plugged my phone playing music directly in to channel 1 of the speaker amp and still got no sound, does this point to a broken first amp? |
#9 |
Could also mean the amp has a bad ground and is trying to use the RCA to ground, but could be something else too. If it does have a ground problem it has no power.
#10 |
Generally, if the RCAs have voltage (~12v) on the shield, the transformer in the amp is shorted. If you read 0 ohms between the B+ terminal and the input RCA shields, the transformer is shorted.
| ... Vintage Velodyne from 1994... | experiencethemusic | Subwoofers | 3 | 28th October 2012 04:47 PM |
| Self Installation in 1997 Oldsmobile Cutlass | spency7321 | Car Audio | 6 | 16th November 2011 11:11 PM |
| Were MJ15024-5 equivalent available in 1994? | indianajo | Parts | 4 | 30th April 2011 04:13 PM |
| Upgrading a 1994 amplifier | cvalde | Solid State | 3 | 11th November 2010 02:07 AM |
| Marantz 1994 Catalogue | speedmetal | Digital Source | 0 | 15th January 2005 05:08 AM |
