Rockford Fosgate Type RF X6 Rockford Fosgate Type RF X6 - Page 4 - diyAudio
Old 8th January 2013, 09:14 AM   #31
Perry Babin is offline Perry Babin  United States
It's not always easy to determine if the signal is good because it's floating. You have to use the scope in differential mode and place the probes on pins 1 and 3 of the output (without slipping and blowing them out).
I think that U21 was pulling pin 18 down and that was causing the problem (if that was indeed the problem). I've seen U21 leak plenty of times from pin 6 to the negative supply pin but never from pin 5 to the negative supply pin.
Old 8th January 2013, 09:55 AM   #32
seankane is offline seankane  United States
seankane's Avatar
Changed the opto-coupler and the driver for good measure. I also had to replace the infrasonic and phase switches.
The amp sounds great, but cant load it hard until tomorrow, little one sleeping.
Thanks Perry.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 9th January 2013, 06:34 AM   #33
seankane's Avatar
I ran the amp hard and punished the old 18" xlc and I noticed the output of the amp going up and down on its own. I found when I pushed on the cross over pot and the gain pot it got alot louder.
I replaced both pot and this amp pounds something fierce!!
I ran it for about 30 min with no issues. Didnt even get remotely warm to the touch either.
Thanks again for the help.
Rockford Fosgate Type RF X6Hide this!Advertise here!
Rockford Fosgate type RF X7 seankane Car Audio 32 16th October 2016 05:50 AM
Rockford Fosgate Type RF X6 seankane Car Audio 24 22nd November 2012 07:19 AM
Rockford Type RF X2 seankane Car Audio 3 8th February 2012 05:00 AM
Rockford Fosgate RF? - Model unknown sync clips Dr Zeus Car Audio 40 10th December 2010 01:17 PM
rockford RF X3 scampo77 Car Audio 23 8th April 2010 12:43 AM
Copyright ©1999-2017 diyAudio
