Jl Audio 500/1
Jl Audio 500/1
Old 6th January 2013, 11:00 PM   #1
joesch1999 is offline joesch1999  United States
Default Jl Audio 500/1
Anyone know what the z 44 drivers r they are marked 232
Old 6th January 2013, 11:17 PM   #2
Perry Babin is offline Perry Babin  United States
You need the letters above that.
Old 6th January 2013, 11:36 PM   #3
Perry there is a uy and wy, I replaced all the z44's 560's and the rectifier next to the z44's at least I think thats what it is amp will play music for a second then quit repeats, never goes into protection, one of the drivers the wy is burnt I did not notice it before, would that cause the problem I checked it in curcuit, i know one leg is supposed be unsoldered then checked but it's burnt so assuming it's bad
Old 6th January 2013, 11:43 PM   #4
It's a KTA1666 but that's not generally readily available. If the board isn't damaged too badly to use the same type of transistor, Use a 2SB1260.
Old 6th January 2013, 11:46 PM   #5
thats the wy and the uy?
Old 6th January 2013, 11:52 PM   #6
the wy is pnp and the uy is npn right
Old 6th January 2013, 11:53 PM   #7
That's for the WY transistor. Did the other one fail as well? For the UY, you can use a 2SD1898.
Old 6th January 2013, 11:54 PM   #8
#6:
Yes. Look up the datasheets for information about the transistors.
Old 6th January 2013, 11:57 PM   #9
no it didn't fail I just figured I would get some, I have repaired about six of the jl 500/1 never had problems with the drivers I guess i got lucky, your a lifesaver thanks alot perry
Jl Audio 500/1Hide this!Advertise here!
JL AUDIO 500.1 mike49504 Car Audio 8 30th August 2017 08:32 PM
Jl audio 500/1 help Rzabo2004 Car Audio 26 25th November 2012 06:27 PM
JL Audio 500/1 S Merlington Car Audio 4 7th September 2012 04:57 AM
JL Audio 500/5 help please! Black Frog Car Audio 24 13th March 2012 07:33 AM
JL Audio 500/1 mike49504 Car Audio 55 23rd September 2011 05:26 AM
