Hifonics Zeus zrx-3000.1d Help!!!
Old 19th February 2013, 08:21 AM   #41
Perry Babin is offline Perry Babin  United States
Generally, you need about 3-4 volts of headroom (beyond the rated voltage of the regulator) to determine if it's working. That's hard to do since most 12v supplies only go to about 14.5v.
The positive regulator should have rail voltage on its center leg. The voltage on its output leg should be about 12v above the positive rail. The voltage on it's input leg should be about 15-20v greater than the positive rail. Check to see if that's what you have.
Old 20th February 2013, 01:41 AM   #42
charles75212 is offline charles75212
Hello Perry. These are the measurements for the regulators. I triple checked these measurements because it appears that L7812(positive regulator) has negative values and L7912(negative regulator) has positive values. Here are the numbers. L7812 = 1.(Input = -65.63V), 2. (Ground = -71.7V), 3. (Output = -66.4V). L7912 = 1.(Ground = 71.7V), 2.(Input = 67.6V), 3.(Output = 68.7V). Thanks.
Old 20th February 2013, 04:39 AM   #43
You're right. The negative regulator is on the positive rail and the positive regulator is on the negative rail. It appears that there isn't sufficient input voltage. Are the FETs for the transformer with the additional windings OK?
Hifonics Zeus zrx-3000.1d Help!!!Hide this!Advertise here!
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 06:31 PM
hifonics hifi1000.1d ian33 Car Audio 29 13th April 2012 04:37 AM
Hifonics GEN X Zeus mike49504 Car Audio 18 18th June 2011 07:31 PM
Hifonics Zeus Gen X Dr Zeus Car Audio 19 7th January 2011 03:25 AM
Hifonics zeus gen x mike49504 Car Audio 93 21st April 2010 12:20 AM
Copyright ©1999-2017 diyAudio
