Go Back   Home > Forums > General Interest > Car Audio
Old 8th January 2013, 02:55 AM   #21
I meant 2SA1275 & 2SC3228. Sorry.
Old 8th January 2013, 03:27 AM   #22
They are probably the driver transistors. They act as a buffer between the driver board and the FETs.
Old 30th January 2013, 11:42 PM   #23
Hello Perry. I'm back. Here's an update. First, I fixed the problem with the amp only pulling .204 volts from the power supply. The solder pads on the driver transistors(2SA1275 & 2SC3228) were burnt pretty bad so I used a jumper wire to connect them. I discovered that I had the jumper wire in the wrong place. Once I corrected that problem, the amp powered up just fine and the relay did engage. Now, I replaced all the output transistors(IRF640N & IRF9640) and re-installed all the power FETS(IRFP064N) and the amp powers up just with no FETS overheating or failing like in the beginning. The problem I have now is when I connect a speaker to it, I only get a feedback\humming noise and that's with and without a signal through the audio input. I have positive & negative rail voltage(+/-24Volts) across the dual rectifiers and output transistors(IRF640N & IRF9640). Your assistance is greatly appreciated. Thanks.
Old 31st January 2013, 12:48 AM   #24
Do any of the controls on the amp make any difference in the hum?
Are you saying that absolutely nothing was connected to the RCA jacks?
Old 31st January 2013, 12:59 AM   #25
Hi Perry. When I increase the volume knob, you can hear the change of pitch if that makes any sense. And Yes, that's with and without anything connected to the RCA jacks. I actually have it powered up in front of me right now.
Old 31st January 2013, 01:05 AM   #26
Can you make the hum change if you push on the various pots?
Does it produce audio?
Don't check for audio unless you clamp the FETs.
Old 31st January 2013, 01:10 AM   #27
I have to admit Perry that I do not have any of FET's or output transistors clamped. These black clips are not that easy to take on & off all the time so I thought I could get away with testing for audio for a few seconds without them. I guess not. My bad.
Old 31st January 2013, 01:13 AM   #28
The clamps are only to reduce the chance of destroying the FETs. They should not affect the hum.
If you haven't seen THIS, it may help with the clamps.
Old 31st January 2013, 01:22 AM   #29
Cool. Thanks Perry. I'll pop the clamps back on and continue testing. Give me a few minutes and I'll see if the humming changes when I push certain pots.
Old 31st January 2013, 02:03 AM   #30
Ok Perry. I popped the clamps back on. I powered up the amp and I get still get the humming noise, so I decided to run a signal through it with my iphone on HBO and you hear the audio but it isn't clean. When I turn the volume up, you can hear the audio increase but it isn't clean at all. It almost sounds as if someone is underwater.
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 05:31 PM
hifonics hifi1000.1d ian33 Car Audio 29 13th April 2012 03:37 AM
Hifonics GEN X Zeus mike49504 Car Audio 18 18th June 2011 06:31 PM
Hifonics Zeus Gen X Dr Zeus Car Audio 19 7th January 2011 02:25 AM
Hifonics zeus gen x mike49504 Car Audio 93 20th April 2010 11:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
