Hifonics Zeus zrx-3000.1d Help!!!
Old 7th January 2013, 10:17 PM   #11
Perry Babin is offline Perry Babin  United States
Do you mean that the supply was being dragged down from 12v to 0.203v DC?
For the amp to be reliable, you need to replace all of the transistors that were in parallel with the ones that failed. The ones with matching part numbers need to be from the same batch of parts so that they are relatively well matched.
Old 7th January 2013, 11:26 PM   #12
charles75212 is offline charles75212
Yes.
Old 7th January 2013, 11:29 PM   #13
Ok. I will place an order from Digikey for the output transistors and replace them all. I will post the results once I'm done. Thanks Perry.
Old 8th January 2013, 02:51 AM   #14
If the amp is dragging the voltage down on the supply and is wasn't previously doing that, you need to find why it's dragging the voltage down. It's generally due to a shorted diode, shorted power supply FET or a solder bridge.
Of course, it depends on how your supply reacts to an overload. It could be that any load greater than it's rated current will cause it to shut down until the load is completely removed.
Does it drag the supply down before applying remote voltage?
Old 8th January 2013, 03:03 AM   #15
Yes. Even with the remote voltage applied, it still drags down the voltage. I can test the 4 diode transistors between the output transistors and FET transistors. I've already checked the 2 diodes by the B+ and ground inputs.
Old 8th January 2013, 03:07 AM   #16
I'm assuming that you meant 'without' remote voltage applied.
Are you sure that you didn't have the B+ and ground connections reversed?
Old 8th January 2013, 03:23 AM   #17
Yes. I'm sure. With or without remote voltage, I get the same voltage drop which is .203V. Once I remove the B+ or ground lead from the power supply, it immediately goes to 12 Volts.
Old 8th January 2013, 03:37 AM   #18
Is there anyway possible to get the schematics for this amp?
Old 8th January 2013, 03:44 AM   #19
Try contacting Hifonics. It's unlikely that they will release it but you may get lucky.
Old 8th January 2013, 03:54 AM   #20
Ok. I have another question for you Perry. What does the NPN/PNP transistors(2SA1795 & 2SC32258) control when dealing with the FET transistors.
Hifonics Zeus zrx-3000.1d Help!!!Hide this!Advertise here!
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 06:31 PM
hifonics hifi1000.1d ian33 Car Audio 29 13th April 2012 04:37 AM
Hifonics GEN X Zeus mike49504 Car Audio 18 18th June 2011 07:31 PM
Hifonics Zeus Gen X Dr Zeus Car Audio 19 7th January 2011 03:25 AM
Hifonics zeus gen x mike49504 Car Audio 93 21st April 2010 12:20 AM
