Go Back   Home > Forums > General Interest > Car Audio
Old 3rd January 2013, 10:19 PM   #1
Default Orion Xtreme 800.4
Hello,
I've recently picked up an old Orion Xtreme 800.4 which was faulty. Opening it up I found that the PS FETs on one side had all failed and also the two driver transistors (Q59 & 60) and one other Q34.
I've replaced everything like for like and the amp powers up OK, idle current is about 1.5A, rail voltage is a good +- 30v and it plays audio cleanly from all 4 channels.
After running for 10 minutes I've noticed that one side of the PS transformer is much warmer than the other but not hot. There is also a resistor array (R135) that is also getting warm along with what I think is one of the 15V regulators on the under side of the board.
The only thing I've noticed is that there is some noise on the feed to the side of the transformer that's getting warm. I've attached a picture of the waveform for my scope and sorry for the quality. As you can see there is a about a 5v spike on the waveform. Is this something to worry about and causing things to warm up?
Nick
Old 4th January 2013, 12:16 AM   #2
Do you mean that one transformer is warmer or do you mean that 1/2 of one of the transformers is getting warm?
The spike isn't significant but if it's on only one transformer, it could mean that there is a problem with the circuit driving it.
Can you post a photo of the power supply area in the amp?
Old 9th January 2013, 11:40 AM   #3
Sorry for the delay in getting back to you.
One half of the transformer is warmer than the other side.
Attached are a couple of pictures of the PS.
Old 9th January 2013, 11:46 AM   #4
Is it possible that some of the components on the board are getting hot and causing the transformer to heat up?
orion cobalt 800 timwebb Car Audio 4 27th May 2012 01:28 AM
Orion xtreme 3752 help jasexile Car Audio 1 29th December 2011 07:09 AM
Xtreme 800 acebaker Car Audio 11 27th May 2011 12:06 AM
orion extreme 800 amp 2potter Car Audio 4 7th March 2011 09:39 PM
orion 800.2 amp ampjunkielikeme Car Audio 7 13th April 2009 04:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
