another no name amp
another no name amp
Old 1st January 2013, 09:04 PM   #1
timwebb is offline timwebb  United States
Default another no name amp
ok i got a strange issue im working on one of these no name amps. and i have - voltage on both regulators. i pulled them both out and still getting a negative voltage?
Old 1st January 2013, 09:26 PM   #2
seankane is offline seankane  United States
seankane's Avatar
Your getting negative voltage where? On the op-amps still, or the pads of the removed regulators?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 1st January 2013, 09:53 PM   #3
on the pads where the regulators are and at the opamps
another no name ampHide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
