diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Lanzar MXA 282 (http://www.diyaudio.com/forums/car-audio/226722-lanzar-mxa-282-a.html)
S Merlington 31st December 2012 01:03 AM
Lanzar MXA 282
Got another one of theese in with the same problem..
Amp stsys in protection mode ..
If i remove all of the outputs from the right channel amp will power up and produce clean audio from the left channel..
I replaced every transistor in the right channel put new outputs in it and amp will be stuck in protection mode..
If i remoe all outputs from right channel it will power up
Any ideas??
Perry Babin 31st December 2012 02:24 AM
Check the emitter/source resistors.
S Merlington 31st December 2012 03:00 AM
All check fine ..
They measure 0.5 ohms
Perry Babin 31st December 2012 03:10 AM
Is there a pulse of DC on that channel as you power up the amp?
Post a photo of the board.
S Merlington 1st January 2013 01:44 AM
2 Attachment(s)
Yes i get 0.97 volts on the right channel
The pics are of the other one i have but its the same amp
Perry Babin 1st January 2013 01:56 AM
Can you disconnect the preamp board to see if it will power up?
Does the amp draw excessive current when it attempts to power up?
S Merlington 1st January 2013 01:59 AM
amp does same thing with the preamp board disconnected
Amp doesnt draw excessive current when trying to power up
Perry Babin 1st January 2013 02:02 AM
If you bypass the protection circuit, does the amp draw excessive current?
S Merlington 1st January 2013 02:14 AM
how do i disable the protection ?
Perry Babin 1st January 2013 02:25 AM
Which pin of IC 3 is high?
Resources saved on this page: MySQL 18.75%
