Lanzar MXA 282 - Page 5 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th January 2013, 02:54 AM   #41
And as of right now, do you have the rest of the parts in the board and still have -rail on the output?
Is R176 within tolerance?
Old 5th January 2013, 02:57 AM   #42
All of the parts are in the amp..
R176 measures 4.65 ohms
I have 51 volts of rail on the right channel outputs The voltage is positive rail..
Old 5th January 2013, 04:04 AM   #43
Post the DC voltage on all 3 legs of the 4 differential amp transistors. You may end up needing to post the voltage on virtually all of the transistors but we need to start with these.
Old 5th January 2013, 04:11 AM   #44
what ones are the differential transistors?
Old 5th January 2013, 04:19 AM   #45
The 4 with their emitters connected to the 4 100 ohm resistors in the middle of the channel.
NTSHRM800 (<< ignore).
Old 5th January 2013, 04:31 AM   #46
A970
Leg 1:-2.98
Leg 2:-4.26
Leg 3:-3.59
A970
Leg 1:-3.11
Leg 2:-52.1
Leg 3:-3.71
C2240
Leg 1:-4.27
Leg 2:-4.27
Leg 3:-3.60
C2240
Leg 1:-4.34
Leg 2:-4.33
Leg 3:-3.72
Old 5th January 2013, 04:46 AM   #47
Copy and paste it and add the circuit board designations.
Old 5th January 2013, 04:50 AM   #48
Q110- A970
Leg 1:-2.98
Leg 2:-4.26
Leg 3:-3.59
Q109-A970
Leg 1:-3.11
Leg 2:-52.1
Leg 3:-3.71
Q106-C2240
Leg 1:-4.27
Leg 2:-4.27
Leg 3:-3.60
Q105-C2240
Leg 1:-4.34
Leg 2:-4.33
Leg 3:-3.72
Old 5th January 2013, 05:47 AM   #49
The center legs of those transistors should be near rail voltage. Follow the traces back. You likely have a bad solder connection on a jumper. Don't just resolder them. If you have a bad solder connection, you need to remove the jumper, scrape it until you have clean copper then replace it. If it's easier to use new wire, do that.
Old lanzar help needed Buggen Car Audio 0 13th May 2012 05:01 PM
FS: Hammond 282 PT Milkduds Swap Meet 1 21st June 2011 01:16 AM
Lanzar 100q mike49504 Car Audio 26 29th June 2010 05:36 PM
Need Help With Lanzar OptiDrive KansasKowboy Car Audio 2 1st April 2010 02:41 PM
Anyone have Onkyo M-282 Schematics? PB2 Solid State 2 21st November 2007 05:20 PM
Copyright 1999-2017 diyAudio
