#31 |
You cannot rely on voltage within the feedback loop when the loop is open (which it is with no outputs in the circuit).
Reinstall the outputs.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#32 |
With all the outputs and drivers installed in the right channel heres what i get..
TIP31C Base:-53.3 Collector:52.9 Emitter:-52.6 TIP32C Base:-53.0 Collector:-53.1 Emitter:-52.6 |
#33 |
Have you removed and checked all of the transistors in the channel for leakage and open junctions as well as shorts?
#34 |
Yes
all test good |
#35 |
Post a good quality photo of the defective channel where all of the circuit board designations are legible.
#36 |
heres a pic of the board..
If i remove transistor Q114 (red arrow pointin to it) The voltages will go back to normal on the drivers in the right channel and it will play clean audio but the audio is muted.. I replaced it with a new one and the voltage comes back.. Last edited by S Merlington; 5th January 2013 at 02:11 AM. |
#37 |
Is there any significant DC on J35?
Do you have clean audio there.
#38 |
On J35 i have -3.83 volts
I dont have clean audio on J35 |
#39 |
Remove the transistor just below the circuit board designation R224 in the photo. Does that eliminate the DC on that jumper?
#40 |
No
| Old lanzar help needed | Buggen | Car Audio | 0 | 13th May 2012 05:01 PM |
| FS: Hammond 282 PT | Jimmy D. | Swap Meet | 1 | 21st June 2011 01:16 AM |
| Lanzar 100q | mike49504 | Car Audio | 26 | 29th June 2010 05:36 PM |
| Need Help With Lanzar OptiDrive | KansasKowboy | Car Audio | 2 | 1st April 2010 02:41 PM |
| Anyone have Onkyo M-282 Schematics? | PB2 | Solid State | 2 | 21st November 2007 05:20 PM |
