#21 |
That would tend to indicate that you have no negative rail voltage on those drivers.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 |
If i remove the TIP31C and TIP 32C and the A970 and C2229 heres what i get on the pads for the drivers..
TIP31C Leg 1:-0.21 Leg 2:52.9 Leg 3:0.00 TIP32C Leg 1:-0.21 Leg 2:-53.3 Leg 3:0.00 If i re-install the C2229 i get the 53 volts on all 3 legs back.. Is there a good sub for thoose ?? I have some C2235's on hand would thoose be a good replacement or no? |
#23 |
On the working channel, do you read 0 ohms between the center legs of the outputs and the adjacent drivers?
#24 |
Yes i read 0.2 ohms
#25 |
Check the dead channel the same way.
#26 |
I get 0.2 ohms on thoose as well
#27 |
Look for a bad solder connection on the PNP output transistor. It may be a jumper feeding the outputs.
#28 |
If i remove all of the outputs and drivers from the right channel the 51 volts remains..
If i remove the C2229 the voltage is gone.. So i guess i will go touch up all of the solder connections in that channel and test the transistors.. If i do find that the C3229 is defective is there a good sub for it ?? The collector of the C2229 connects to the base of the TIP32C |
#29 |
You cannot have a loss of negative rail on the center leg of the transistors (PNP outputs and drivers) unless there is a bad connection to the negative rail. I'm assuming that this is a standard Asian design that takes the output from the emitters of the outputs.
#30 |
I have the outputs and Drivers roved from the right channel..
I reflowed all the solder connections in the right channel.. Heres what i get on the pads for the Tip 31c,32c TIP31C Base:-53.2 Collector:52.9 Emitter:0.00 TIP32C Base:-53.2 Collector:-53.3 Emitter:0.00 Theese voltages still dont look right to me any thoughts? |
| Old lanzar help needed | Buggen | Car Audio | 0 | 13th May 2012 05:01 PM |
| FS: Hammond 282 PT | Jimmy D. | Swap Meet | 1 | 21st June 2011 01:16 AM |
| Lanzar 100q | mike49504 | Car Audio | 26 | 29th June 2010 05:36 PM |
| Need Help With Lanzar OptiDrive | KansasKowboy | Car Audio | 2 | 1st April 2010 02:41 PM |
| Anyone have Onkyo M-282 Schematics? | PB2 | Solid State | 2 | 21st November 2007 05:20 PM |
