KX1200.1 in repair
KX1200.1 in repair
Old 1st January 2013, 07:34 PM   #31
Perry Babin is offline Perry Babin  United States
That resistor has been on amps that I've seen so it's likely a factory mod.
Is it still producing about 20v on the output filter inductor?
Old 1st January 2013, 08:12 PM   #32
Kleinteich2 is offline Kleinteich2
yes.. i also removed the fast recovery diodes and now i can actualy read the rail voltage on both sides. but i get no power at the other end of the board because of that. it seems as if everything on the power supply side is good.
with those out it does not cycle in and out of protect.
Old 1st January 2013, 08:24 PM   #33
Which diodes?
Old 1st January 2013, 08:41 PM   #34
D12,D13,D14,D15
Old 1st January 2013, 09:07 PM   #35
What are you referring to as 'rail' voltage? With those out of the circuit, the rail voltage isn't being produced.
Old 1st January 2013, 09:23 PM   #36
ac voltage.
i cant read any thing steady with the amp swinging from power to protect. with these out i could read everything on the power supply.
Old 1st January 2013, 11:55 PM   #37
Is it producing both positive and negative 15v on the power supply pins of the various op-amps?
Old 2nd January 2013, 01:18 AM   #38
no.just positive +12vdc and +44.34vac. i havnt found a negative ac circuit yet with my dmm.
Old 2nd January 2013, 01:27 AM   #39
What are the numbers on the components just beyond the rectifiers that you removed?
Old 2nd January 2013, 04:17 AM   #40
two of YG225N2
and two YG2252.
i believe these are what your asking for?
KX1200.1 in repairHide this!Advertise here!
kicker kx1200.1 getmoney2957 Class D 1 7th July 2012 11:24 PM
Kicker KX1200.1 whitejohnny Car Audio 7 16th June 2012 07:13 AM
Kx1200.1 megael9 Car Audio 4 29th May 2012 11:54 PM
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
Kicker kx1200.1 catfishermike Car Audio 3 18th April 2010 02:50 AM
