KX1200.1 in repair
KX1200.1 in repair
Old 31st December 2012, 10:16 PM   #21
Perry Babin is offline Perry Babin  United States
With the black probe on the point where you connected the jumper, what is the DC voltage on pins 9 and 11 of U14?
Old 31st December 2012, 10:30 PM   #22
Kleinteich2 is offline Kleinteich2
pin 9- 11.68v
pin 11- 11.67v
Old 31st December 2012, 10:40 PM   #23
Please don't use a hyphen as a separator. In can be taken to mean negative. This is covered on the basic repair page (which you should read now if you haven't done so already).
With the black probe on pin 10 and the red probe on pin 14, what DC voltage to you read?
Old 31st December 2012, 11:48 PM   #24
i have read the repair guide a few times. this isnt my first repair and i just about read your repair guide everytime i fix an amp.
i will remamber not to use them again. srry. newb mistake.
and i will have to check them tomorrow morning when i get to the shop. does it start to seem as if the lm361 is bad?
Old 1st January 2013, 12:30 AM   #25
Until you stated that you had 12v on pins 9 and 11, it seemed likely but that voltage is very far off of what it should be so there may be multiple problems. I need the voltage across pins 10 and 14 to see what the total voltage is on the logic side of the IC.
Old 1st January 2013, 02:08 PM   #26
the highest it got on my meter was .98v dc. but it drops back off when it pulses power protect. on my meter it read 0.2v, 0.5v, 0.98v. then it drops into protect. this all happens in about two seconds. and then it repeats itself.
Old 1st January 2013, 03:34 PM   #27
What is the DC voltage with the black probe on the amp ground terminal and the red probe on the negative speaker terminal?
Old 1st January 2013, 03:36 PM   #28
with it cycling in and out of protect?
Old 1st January 2013, 03:39 PM   #29
the highest reading i got was 0.4vdc.
Old 1st January 2013, 03:59 PM   #30
someone before me. worked on this amp and there is a resistor marked 433 jumping from the base of Q144 to resistor R230.. any idea why they did this?
KX1200.1 in repairHide this!Advertise here!
kicker kx1200.1 getmoney2957 Class D 1 7th July 2012 11:24 PM
Kicker KX1200.1 whitejohnny Car Audio 7 16th June 2012 07:13 AM
Kx1200.1 megael9 Car Audio 4 29th May 2012 11:54 PM
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
Kicker kx1200.1 catfishermike Car Audio 3 18th April 2010 02:50 AM
