KX1200.1 in repair
KX1200.1 in repair
Old 31st December 2012, 07:44 PM   #11
Kleinteich2 is offline Kleinteich2
this thing is really getting on my last nerve.. lol..
Old 31st December 2012, 08:03 PM   #12
Perry Babin is offline Perry Babin  United States
If you're asking for help, you should be patient. It's likely that the problem is unrelated to any of the FETs.
The 100 ohm resistors are OK in many of the kicker amps that use 3205s because they program in extra deadtime.
It's likely that U14 is defective. Find a point near U14 that reads 0 ohms to the negative speaker terminal. The via directly above the '4' in C274 should read 0 ohms. If not find one that does. Connect a jumper from there to pin 3 of U4. With ALL of the FETs in the circuit, do you still have DC on the output filter inductor?
Old 31st December 2012, 08:39 PM   #13
i wasnt being pushy on a response. i really appreciate every word of advice you type. ok i found the small solder pad that is right above the 4 on c274. so u connect the jumper wire to the number 3 leg on u04 right? or is there a part on the board that is just U4?
Old 31st December 2012, 08:51 PM   #14
It's likely due to impatience than being pushy.
First you have to confirm that you read 0 ohms between that point and the negative speaker terminal.
Old 31st December 2012, 08:55 PM   #15
i did. it reads 0.000ohms on my meter.
Old 31st December 2012, 09:02 PM   #16
Pin 3 on U14. It's about 1/2" from that point.
Old 31st December 2012, 09:18 PM   #17
pin 1 being where the imprinted dot on top of u14 is right?
Old 31st December 2012, 09:23 PM   #18
See attached.
Old 31st December 2012, 09:39 PM   #19
See attached.
like this right. i just want to make sure.. srry for all the dumb questions.
Old 31st December 2012, 09:51 PM   #20
ok i just hooked it up and i still have dc voltage on the output filter inductor.
KX1200.1 in repairHide this!Advertise here!
kicker kx1200.1 getmoney2957 Class D 1 7th July 2012 11:24 PM
Kicker KX1200.1 whitejohnny Car Audio 7 16th June 2012 07:13 AM
Kx1200.1 megael9 Car Audio 4 29th May 2012 11:54 PM
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
Kicker kx1200.1 catfishermike Car Audio 3 18th April 2010 02:50 AM
