happy holidays to all
thank you for taking the time to check my listing .I just took this amp as a trade in from the original owner ,the issue was that one of the channels has lower output than the other 3.the bad channel has clean output its just allot quieter that the other 3 -i would say 10 watts tops .operating the switches in all ranges and using other source and rca cable dosent change anything .please advise |
#2 |
I don't have anything on that amp but similar amps have 1 or 2 muting transistors for each channel. They typically have the lowest circuit board designations for the channel. Find the muting transistor(s) for the weak channel. Compare the audio level on the muting transistors in the other channels. If the the audio is weaker on the weak channel, remove the muting transistors to see if that makes a difference.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
| L channel lower output? | Martin Prothero | Tubes / Valves | 3 | 11th October 2012 08:25 PM |
| kicker kx850.2 overheat | Dannie717 | Car Audio | 4 | 8th August 2012 02:03 PM |
| How to lower preamp output? | BobBeaston | Tubes / Valves | 10 | 2nd August 2010 03:46 PM |
| Lower than expected output | bushroot | Solid State | 19 | 31st July 2006 01:15 AM |
