Go Back   Home > Forums > General Interest > Car Audio
Old 28th December 2012, 09:07 PM   #1
Default Soundstream Rubicon 604
Amp powers up and produces both + - rail voltages also produces both + - 15 volts on all op-amps..
Amp has no sound and all 4 of the clip lights are solid red all of the time..
Any ideas??
Old 29th December 2012, 12:35 AM   #2
The clip leds are shunted/switched by a MPS8599 transistor that gets it signal from the FEB modules. The transistor shunts across the led and it base is driven from one of the FEB's outputs. Check Q101, Q102, Q122, and Q123 for proper operation.
The rails should be as below:
P. S. RAILS: HV: +/- 29.5V
HC: +/- 23V
RB: +/- 18V
Hope some of this info is helpful...
Old 29th December 2012, 01:44 AM   #3
Q101, 102, 122, 123 all have the same voltages on them
They test fine out of the board heres the voltages i get
Emitter:29.22
Base:28.54
Collector:29.22
Clip lights went off but amp still has no output
Old 29th December 2012, 02:16 AM   #4
Ok if i plug the Rca jacks into channels 3 and 4 i get sound from all channels..
If i plug the rca's into channels 1 and 2 i get no sound..
Any ideas?
Old 29th December 2012, 02:51 AM   #5
Rca input switch, rca solder broken?
Old 29th December 2012, 04:54 AM   #6
Are you sure that you don't have that backwards? The amp can feed all 4 channels with input from channels 1 and 2 but not by feeding 3 and 4 (unless I'm misreading the manual).
http://www.soundstream.com/manuals/A...b204404604.pdf
Old 29th December 2012, 05:29 AM   #7
Ok yeah channels 1 and 2 feed all 4 channels..
If i plug the rca jacks in channels 3 and 4 i get no sound..
The Rca Jacks for the RCA outputs are broken ..
Anyone know where i can buy a new set of Jacks or does anyone have some laying around i can buy ??
Old 29th December 2012, 05:39 AM   #8
There is a switch on the bottom of the amp that allows you to feed all channels individually. It's shown in the manual.
I don't have a source for the jacks. How are they broken?
Old 29th December 2012, 05:41 AM   #9
The part where u plug the rca jack into is snapped off
Old 29th December 2012, 05:51 AM   #10
It won't be a perfect match but if you have no other options, maybe something like THIS will work.
Soundstream Rubicon 604 not powering on azvrt Car Audio 6 9th February 2012 05:01 PM
Soundstream Rubicon 604 not playing nicely... frekiy Car Audio 11 23rd January 2012 10:31 AM
Soundstream Rubicon 1002 mike49504 Car Audio 6 30th November 2010 03:41 PM
Soundstream Rubicon 302 mike49504 Car Audio 20 6th June 2010 02:09 AM
Soundstream Rubicon 805 audiobahnkid592 Car Audio 16 23rd July 2008 10:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
