Repaired a JL Audio 300/4 Ver1 series with very low audio output on all 4 channels. After some troubleshooting and voltage measurements found pin 3 of U600 on the daughter board had no voltage on it. Pin 3 usually measures approx 4VDC. Problem found to be a open trace connecting R612-R615 caused by a corroded via (plated through hole) had no continuity between top and bottom of brd. See picture.
Hope this info is of help to someone. |
#2 |
Thanks for the info and picture....Good catch!
Tek 2221 scope with 2 10x probes, 2 Fluke 115 true rms meters. 106a, 20a & 5a power supplies. I have read the BCAE scope page. |
#3 |
This is a common problem on JL amps. It always seems to happen near the power/ground terminals. Green corrosion in the vias is a sign that there's a problem. There are almost always several that are near opening (either the pad around the via or the via itself). Many times, you need a high-power lighted magnifying glass to see the damaged (but still connected) traces.
THIS is another thread with a few photos showing the type of damage to look for.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#4 |
I had 7 other corroded open via's I repaired on the same board including 2 under IC U600. I scraped the coating on the foil both sides to expose the copper, used a dental pick to open up the hole a bit and used 30 gauge buss wire to fill the hole. I used liquid flux to provide better flow through for the solder.
Between the Luxo lamp and a eyeloop I was able to see the corroded via's but some that looked good I found with a meter. I'll have to try that # 80 drill bit method you mentioned in the other JL Audio thread next time. |
| JL Audio 500/1 - low distorted output, melted LED wires | craig469 | Car Audio | 7 | 26th September 2011 07:53 PM |
| JL Audio 500/1v1- Low Output | gsxtasy | Car Audio | 21 | 7th September 2011 01:46 AM |
| Jl audio 500/1 powers on with low audio out help needed | ivkata | Car Audio | 29 | 19th August 2011 12:21 AM |
| Jl Audio 300/4 Troubleshooting Tip | kds9591 | Car Audio | 3 | 31st May 2011 01:42 PM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
