Orion 2350GX
Orion 2350GX
Old 14th January 2013, 09:44 AM   #11
Perry Babin is offline Perry Babin  United States
The voltage isn't the issue. The output impedance of the head unit could be but probably isn't an issue.
You could use the correct value and use a screwdriver to adjust the gain. In my opinion, that would be the best option if you can't find the original pots.
What wrong with the originals? If the back has popped out, it can be popped back it. If they're noisy, they can generally be cleaned.
Old 14th January 2013, 09:51 AM   #12
seankane is offline seankane  United States
seankane's Avatar
The preamp output impedance of the head unit is 50 ohms.
The legs are broke off one pot and one has popped apart.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 14th January 2013, 10:10 AM   #13
In my opinion, it's better to have an amp look a bit different and remain original, electronically. It's your amp so you'll have to make the decision.
With a 50 ohm output impedance (assuming that the impedance is flat across the audio spectrum), the 10k pots won't make a difference.
Old 14th January 2013, 10:12 AM   #14
seankane's Avatar
They are actually 5k pots, I guess I will try them and see.
Old 14th January 2013, 10:15 AM   #15
I was referring to the replacement from mouser that I posted. 5k would work for testing.
Orion 2350GXHide this!Advertise here!
Old School Orion 2350GX Anyone have tech info? SomeGuyInPDX Car Audio 137 26th December 2011 05:48 AM
Orion 2350gx right channel not developing full power SomeGuyInPDX Car Audio 4 3rd November 2011 03:09 PM
Orion #5 Clipped Car Audio 1 21st November 2008 04:34 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
