Alpine MRV-1507 - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 3rd January 2013, 06:24 AM   #31
Are you measuring across the speaker terminals?
Post a photo of the components in the channel with DC.
Old 3rd January 2013, 06:50 AM   #32
seankane's Avatar
Yes across the speaker terminals.
This is a photo of the half of the output board that is giving me trouble.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 3rd January 2013, 07:17 AM   #33
Connect a dummy load across the speaker terminals. Does that stop the DC and allow the amp to power up or does the amp draw excessive current?
Old 3rd January 2013, 07:22 AM   #34
seankane's Avatar
Connecting a 4 ohm dummy load allows the amp to power up and be stable with solid green light but the red protection light is flashing.
The pulsing DC is gone as well.
Old 3rd January 2013, 07:25 AM   #35
Did you find any outputs that were shorted or leaky?
Old 3rd January 2013, 07:34 AM   #36
seankane's Avatar
I have not tested them yet, why does the dummy load remove the DC and allow the amp to power?
Is the red protection light flashing because the outputs are removed?
Old 3rd January 2013, 07:40 AM   #37
The DC source causing the DC on the speaker terminals without the outputs likely has significant resistance. If not, it would cause the amp to draw excessive current.
The red LED blinking may be a separate problem.
Old 3rd January 2013, 07:45 AM   #38
seankane's Avatar
2 outputs were shorted and 2 were leaking from that channel.
Could a defective driver be causing the DC source?
Why does the dummy load get rid of the DC and allow the amp to power?
Old 3rd January 2013, 07:54 AM   #39
seankane's Avatar
Q419 a C2682 has full rail on every leg.
Q420 a C2682 does not from the other channel.
In the picture they are the 2 components that are screwed down to the heat sink still where the fets clamp down.
Just poking around and thought I would mention it??
Old 3rd January 2013, 08:02 AM   #40
You can't rely on DC voltage with the outputs out of the channel.
Alpine MRV 1507 Tom7227 Car Audio 1 15th June 2012 05:02 PM
Alpine MRV-1507 mike49504 Car Audio 2 2nd February 2012 06:43 AM
Alpine MRV-1507 canadianeh Car Audio 9 6th April 2011 01:16 AM
Alpine MRV-1507 Dr Zeus Car Audio 15 2nd March 2011 11:17 PM
Alpine MRV 1507 FSUSeminole Car Audio 8 1st January 2011 07:04 PM
Copyright 1999-2017 diyAudio
