#11 |
Does it at any time produce pulses on the gates or drains of the power supply FETs?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#12 |
The drains remain at supply voltage, the gates have about 0.356 vdc on them.
I didnt notice any pulsing.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#13 |
Post the DC voltage on all pins of IC602.
#14 |
Im sorry Perry I dont find an IC602 on the board?
Is it on the bottom side of the board? I see an IC206 but its on the output side of the board and I have the 6 pin wire unplugged still?
#15 |
Yes. It's on the bottom of the board. It's one of the 494s.
#16 |
Will it be safe to power the amp out of the sink disconnected from the output board upside down?
#17 |
I see 2 494's one says IC601 and one says IC605.
Shall I take readings from both? Do I use the battery terminal or direct battery terminal or both when powering this amp? When I power the amp its like it starts to power up drawing a few amps of current then drops to nothing on the meter of my supply.
#18 |
You can use either terminal.
The IC602 is printed mirror image, if you look closely.
#19 |
IC601
1: 0.967 2: 0.963 3: 3.850 4: 0.221 5: 1.668 6: 1.670 7: 0.004 8: 14.53 9: 0.410 10: 0.427 11: 14.53 12: 14.53 13: 5.05 14: 5.05 15: 5.05 16: 0.004 IC605 1: 0.954 2: 0.952 3: 3.873 4: 0.220 5: 1.674 6: 3.762 7: 0.004 8: 14.53 9: 0.433 10: 0.428 11: 14.53 12: 14.53 13: 5.05 14: 5.05 15: 5.05 16: 0.003
#20 |
Reduce the supply voltage to about 13.5v. Does that help?
| Alpine MRV 1507 | Tom7227 | Car Audio | 1 | 15th June 2012 05:02 PM |
| Alpine MRV-1507 | mike49504 | Car Audio | 2 | 2nd February 2012 06:43 AM |
| Alpine MRV-1507 | canadianeh | Car Audio | 9 | 6th April 2011 01:16 AM |
| Alpine MRV-1507 | Dr Zeus | Car Audio | 15 | 2nd March 2011 11:17 PM |
| Alpine MRV 1507 | FSUSeminole | Car Audio | 8 | 1st January 2011 07:04 PM |
