Nakamichi MB-75 e-disc error
Old 22nd December 2012, 03:08 PM   #1
frobek is offline frobek  Poland
Default Nakamichi MB-75 e-disc error
Hallo,
My Nakamichi MB-75 displays e-disc error message on the display.
I red the service manual, but there is nothing about it.
Have you any experience with it?
Old 23rd December 2012, 04:51 AM   #2
seankane is offline seankane  United States
seankane's Avatar
The laser pick up could be dirty or out of alignment. Have to you tried cleaning it with one of those discs and solution?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 28th December 2012, 05:03 PM   #3
I disassembled the unit and I noticed that the spindle motor doesn't work. Any suggestions?
Old 28th December 2012, 05:09 PM   #4
Mooly's Avatar
Car audio isn't my thing but for CD generally the focus point on the disc has to be found before the spindle motor operates. Its easier to focus on a stationery object rather than a spinning one.
Could be the laser or a problem with the focus search routine.
Old 28th December 2012, 05:13 PM   #5
Maybe you are right, laser is trying to focus and isn't able to read the CD.
Old 28th December 2012, 05:16 PM   #6
Mooly's Avatar
Can you see the lens performing the focus search routine ? In other words moving up and and down a couple of times.
Old 28th December 2012, 05:42 PM   #7
Yes, it is moving up and down.
Old 28th December 2012, 06:38 PM   #8
Mooly's Avatar
Next step is to confirm laser is lit. Without a power meter the best you can hope for is a "visual" check (safety warnings apply... don't stare into the beam and don't get to close and on axis to it) and a check of the current consumption of the laser diode but that gets pickup specific.
Old 28th December 2012, 07:03 PM   #9
Yes, but due to the radio construction it is impossible to run it without the CD, but with CD it's hardly to see anything. Anyway I can't see laser light reflection on the CD. I measured voltage on the laser diode it's ca. 2,2V.
Old 28th December 2012, 07:29 PM   #10
Mooly's Avatar
The voltage on the diode won't reveal much, its the current thats the important figure. And that brings another problem because laser diodes are very static sensitive although in circuit there is less of a problem.
I understand what you say regarding accessability... I don't know what to suggest tbh. Maybe there are dedicated jigs and extension leads available but that's hardly a diy option.
It may or may not be a faulty pickup and without the detailed checks needed its not possible to say.
Nakamichi MB-75 e-disc errorHide this!Advertise here!
nakamichi mb-2 disc loading problem deafdumband50 Digital Source 8 1st May 2015 09:32 PM
nakamichi MB-75 george21 Car Audio 2 1st December 2010 04:25 AM
nakamichi mb 75 wesley64 Car Audio 0 2nd January 2010 07:48 PM
Nakamichi MB-75 CD has no sound white93nsx Car Audio 1 18th July 2009 12:56 AM
Nakamichi MB - 75 AUX Input aladdin_s Car Audio 0 15th September 2008 11:02 AM
Copyright ©1999-2017 diyAudio
