Nakamichi MB-75 e-disc error
Old 28th December 2012, 06:36 PM   #11
frobek is offline frobek  Poland
Laser diode is connected to collector of the PNP transistor. I measured voltage on emitters resistor (10 Ohm) and it was 0,41V, so Emitter current was ca. 40mA (Ic+Ib).
Old 28th December 2012, 06:49 PM   #12
Mooly's Avatar
Normally you measure the volt drop across the resistor to get the current. The laser should only be "lit" for the brief moment that the focus search operation is being performed. After that it is turned off. A typical laser current is in the 50ma region but its very device dependent and unless you have the exact value the individual pickup was calibrated at then the measured value can only be a rough guide that the laser is at least drawing somewhere in the expected current range. In full size players many pickups have the value incorporated as part of the pickup serial number for reference.
For general info...
If you take a laser diode and gradually increase the current from zero then it functions first as a side emitting red LED. There is no laser action. As the current increases more and more then suddenly lasing begins and the optical output increases dramatically. From this point a tiny further increase in current causes a massive increase in the optical output. Go a bit to high and the laser is damaged or destroyed. Its a fine window of operating current that is needed and is why the laser diode has an integral photodiode to monitor the "optical" output and maintain the "optical" output at an exact level. The current varies according to temperature and also as the laser ages. The laser power control circuit always tries to maintain the optical power at a constant level by altering the current but this current is always within a fairly narrow window.
Old 28th December 2012, 07:43 PM   #13
The volt drop I measured across the resistor is changing during focusing procedure.
Old 29th December 2012, 03:30 PM   #14
After a couple hours of checking the problem I am almost sure that the laser is broken. And now the question is, if it's possible to buy a KSS-602A pickup laser, or somehow repair it?
Old 29th December 2012, 03:59 PM   #15
Mooly's Avatar
If all checks point to the laser then it its time to look at replacement. I couldn't turn anything up on the KSS 602.
Have you checked to make sure that the spindle motor servo output and motor drive really is "non functional". We're assuming the pickup isn't focusing and that the system control isn't getting the Fok (focus OK) signal.
Its worth looking at the problem from another angle.
Old 29th December 2012, 05:25 PM   #16
During focusing:
I cheked RF amplifier output with oscilloscope - no signal.
On the photodiode output (that one to control laser output power) : voltage level ca. 200mV, change to zero when trying to focus, not always, 1 of 5.
Another possibility is RF amplifier CXA2521 damage.
I didn't check RF amplifier input due to lack of space. I have to solder some wires to connect the oscilloscope.
What do you think I am supposed to check more.
Old 29th December 2012, 06:03 PM   #17
Mooly's Avatar
All I could think of was to check the spindle motor drive amp during focus search. That would be just to confirm that the motor isn't spining up purely because there really is no spindle drive output from the servo. Very unlikely the problem would be there but it just covers all bases before deciding the pickup is faulty. Any measurements would have to be done during the brief focus search time.
And never overlook supplies. Are they all correct and not low. Once you've done all that then the pickup is the most likely suspect.
Old 29th December 2012, 07:01 PM   #18
I checked spindle motor driver out. - no signal. Power is ok.
Old 29th December 2012, 07:40 PM   #19
freax is offline freax
freax's Avatar
I once span a sony playstation playing a music cd by hand, it worked and gave an audio output.
I'm thinking that If you can spin it fairly fast it might lock on, if its that then you know where the problem is.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 29th December 2012, 08:18 PM   #20
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
welcome to the wonderful world of Nak car stereo's....I gave up on them! the cd-changers always had problems!
It's not about what you can BUY...It's about what you can BUILD!
Nakamichi MB-75 e-disc errorHide this!Advertise here!
nakamichi mb-2 disc loading problem deafdumband50 Digital Source 8 1st May 2015 08:32 PM
nakamichi MB-75 george21 Car Audio 2 1st December 2010 03:25 AM
nakamichi mb 75 wesley64 Car Audio 0 2nd January 2010 06:48 PM
Nakamichi MB-75 CD has no sound white93nsx Car Audio 1 17th July 2009 11:56 PM
Nakamichi MB - 75 AUX Input aladdin_s Car Audio 0 15th September 2008 10:02 AM
Copyright ©1999-2017 diyAudio
