KICKER KX500.2, HELP
Old 21st December 2012, 02:49 PM   #1
404Amps is offline 404Amps  United States
404Amps's Avatar
Default KICKER KX500.2, HELP
Hello, and Happy Holidays to all.
I have the kx500.2 amp that was cutting out. I goofed by letting the DMM probe slip between the legs of a PS FET. I removed the 1 FET that shorted, and now when I supply power to the amp it does not turn on.
FETs Q15 and Q 16 looks to have overheated but no damaged to the board or trace.
The amp is not blowing any fuses, just won't power up. Can anyone explain what is going with this amp? Ps. I.m using a 7.5a power line fuse.
Old 21st December 2012, 02:54 PM   #2
Perry Babin is offline Perry Babin  United States
Post the DC voltage on pins 10. 11, 12 and 13 of the TL494.
Old 21st December 2012, 03:18 PM   #3
404Amps's Avatar
source V = 12.48
@ amps connector = 0.267v
@TL*94cn
pin 10 = 0v
pin 11 = 0v
pin 12 = 0v
pin 13 = 0v
DMM blk probe on amps main ground
Old 21st December 2012, 03:33 PM   #4
Post the DC voltage and the numbers on the faces for Q1 and Q2.
Old 21st December 2012, 03:45 PM   #5
404Amps's Avatar
Q1 = 2sb649
0.273v
Q2 = 2N4401-047
0.263v
Old 21st December 2012, 04:49 PM   #6
404Amps's Avatar
Q1 = 2sb649
E = 0.258v
C = 0.0v
B = 0.251v
Q2 = 2N4401-047
1 = 0.0v
2 = 0.015v
3 = 0.309v
Old 21st December 2012, 04:55 PM   #7
Are you sure that the fuses are not blown?
Do you have 12v across the B+ and ground terminals on the amp?
Old 21st December 2012, 10:53 PM   #8
404Amps's Avatar
Thank Perry, I did have a bad fuse!.. Amp is now turning on and going green.
Old 22nd December 2012, 03:31 AM   #9
Is it producing clean audio now?
The regulators in these amps tend to overheat. If the board around the regulator transistors or the solder joints show signs of heat stress, you should replace the transistors with larger ones and add heatsinks.
KICKER KX500.2, HELPHide this!Advertise here!
Kicker ZX100.2 Dr Zeus Car Audio 11 28th April 2011 01:49 AM
Kicker c15 Masieniec Parts 0 27th April 2011 06:57 PM
Kicker ZR1000 seankane Car Audio 0 8th April 2011 10:37 PM
kicker box xlcjw72 Subwoofers 1 26th March 2011 12:12 AM
kicker 450.2 timwebb Car Audio 5 26th May 2010 05:59 AM
