Need Help Adding Tweeters to Speakers - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 20th December 2012, 11:11 AM   #11
Okay I see, So I will put the resistor after the main speaker and somewhere before the tweeter or it non polarized cap? I dont know why I am using a resistor but it will get hot and lower output of the midrange speaker? nof if placed before the tweeter right? I was suggested I use a 5 Watt 4 ohms resistor by someone else in another forum who said since both speakers are 8 ohms I need to use a resistor on each side to bring down the impedance level or that its better overall or something like that. How correct is that?
So you guys are telling me I can connect 2 regular 10uF caps and mimic a 4.7uF cap? how is that done exactly, any guides or diagrams?
Thank you for the help, I really appreciate it.
Old 20th December 2012, 11:28 AM   #12
forgot to ask one more thing...the capacitor, does it matter what voltage its rated at? You know some of the ones I have are ratted at 6.3V and some around 10V some 16V.
Also to clearly, When you say it is 4.7uF do you guys actually mean 470uF. So in that case I would grab two 1000uF capacitors, and solider their positive legs together which will make it around 470 - 500uF. right?
Old 20th December 2012, 11:50 AM   #13
Mooly's Avatar
As in post #9
4.7 uf sounds in the right ballpark value wise... give or take depending on exact specs. Its certainly not 470uf.
The voltage of the cap needs to be able to stand the peak voltage the amp puts out. The lower the frequency the more voltage the cap "drops".
Old 20th December 2012, 01:04 PM   #14
If this is a Sony CD player (I missed the make in the first post), the resistor is definitely not required if you are driving only the mid and the tweeter on that channel of the head unit. If you look up the specs for the head unit, you'll likely find that it's designed to drive a 4 ohm load.
You should be able to find a 4.7uf mylar/film or non-polarized electrolytic capacitor at virtually car audio shop.
The capacitor will never see more than 15v if it's driven from the head unit.
Old 21st December 2012, 01:16 AM   #15
Okay Thanks Perry,
Its a Sony CDX-F7710, So I guess I will just skip the resistor altogether? And just hot glue two 10uF caps to the side of per tweeter (with their positive legs connected to each other by a wire) and negative leg connected to the Positive speaker wire and a wire leading to the positive terminal on the speaker. To mimic a non polarized cap? am I right?
I have found some regular 50V 10uF Caps in my tool box.
Old 21st December 2012, 04:08 PM   #16
Okay Thanks Perry,
Let me know guys...thanks
Old 22nd December 2012, 03:22 AM   #17
What is it that was not previously covered that you need to know?
Old 22nd December 2012, 04:34 AM   #18
Just wanted to double check Perry. Wanted to tell you my CD players Model number and caps I am about to use, You know I am new to this so just wanted you to know and confirm thats all. You know just incaase I had something wrong. better be safe then sorry.
Thanks for your time
Adding tweeters, and impedance drop EWorkshop1708 Multi-Way 1 7th August 2011 08:08 PM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
adding tweeters to full range speakers. legendaryfrog Full Range 15 22nd November 2006 06:19 PM
Adding a pair of Jensen 302A tweeters to two way speakers singleended40 Multi-Way 2 23rd August 2006 04:58 PM
Copyright 1999-2017 diyAudio
