RF 250m2 schematic
Its the same as the Power 250.2 I know I have it, its a matter of finding which hard drive its on. I will look now and let you know.
Do you have the x-over cards in full range?
Have you confirmed the bass and treble pots are ok?
Does the channel bias?
I have placed the xover cards every which way and no change.
No bass and treble pots on this amp.
I have not checked the bias, will do that in the morning.
Sent from my DROID BIONIC
Oh yes I forgot this does not have bass and treble pots. Do any of the switches ie: balanced/unbalance or the 0/180 or the 0/180/ez bridge have any DC on the casing?
There is a 0/180 switch for each channel and one of them is 0/180/ez bridge.
Sometimes these switches being bad can cause strange issues.
I am looking for the schematic now.
I found no DC on the shroud of the switch.
Adjusting the bias pot works.
Time to eliminate the shutdown circuits to see if that is the cause.
