RF 250m2 schematic
RF 250m2 schematic
Old 19th December 2012, 05:47 AM   #11
seankane is offline seankane  United States
seankane's Avatar
Did you get it?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 19th December 2012, 11:11 AM   #12
brandes.cm is offline brandes.cm  United States
Got the schematic, thanks.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 19th December 2012, 06:44 PM   #13
seankane's Avatar
Did you read post #9?
Old 19th December 2012, 07:16 PM   #14
I will look into that after work, thanks.
Old 20th December 2012, 03:22 AM   #15
Originally Posted by seankane View Post
Oh yes I forgot this does not have bass and treble pots. Do any of the switches ie: balanced/unbalance or the 0/180 or the 0/180/ez bridge have any DC on the casing?
There is a 0/180 switch for each channel and one of them is 0/180/ez bridge.
Sometimes these switches being bad can cause strange issues.
I am looking for the schematic now.
I found no DC on the shroud of the switch.
Adjusting the bias pot works.
Time to eliminate the shutdown circuits to see if that is the cause.
Old 20th December 2012, 08:46 AM   #16
Perry Babin is offline Perry Babin  United States
Do you see any damaged SMD capacitors?
Are Cx22 and Rx89 within tolerance?
Does loading it with a speaker or dummy load change the amplitude of the oscillation?
Old 20th December 2012, 08:35 PM   #17
Loading the output causes it not work at all. I get a high pitched squeal then no output.
The resistor measures ok, no way to check the cap. It doesn't measure shorted.
Old 20th December 2012, 08:43 PM   #18
Look at the signal on each end of the Rx89. If the amplitude of the oscillation is the same on both ends, the capacitor is open. If it appears to be open, you could connect another capacitor across it to see if it helps.
Old 20th December 2012, 08:56 PM   #19
Adding a cap helped. I get noise on the lower peak of the sine wave at a certain amplitude. I will try a different cap.
Old 20th December 2012, 09:04 PM   #20
No load and the signal looks fine, cap made no difference of course.
Lifting D309 should disable the protection for the low side?
RF 250m2 schematicHide this!Advertise here!
RF T10001BD schematic brandes.cm Car Audio 14 5th November 2017 05:15 PM
Rockford Fosgate Punch 250m2 seankane Car Audio 2 1st February 2012 04:21 AM
Looking for RF T40001.bd Schematic codegen Car Audio 2 28th November 2011 03:03 AM
Rockford Fosgate 250m2 seankane Car Audio 2 14th June 2011 11:00 PM
RF 500a2 schematic brandes.cm Car Audio 1 8th January 2010 07:54 PM
