I have two dead pioneer gm-x862 amps. one was connected in reverse polarity, one was run without a heat sink and has no voltage output from the psu section. The one that was reversed works if i apply voltage to the +-38v section and every transistor in the psu section is shot. The one that was ran with no heatsink does not have output from the psu and when i connect the +-38v rails the - rail draws exessive current. Does that mean that one of the output transistors is dead? Im gonna take the easy route and try to convert them to run on ac power by using the transformer from a 5.1 channal sony receiver. Could i use the amps internal rectifiers or will i need external recitifers? Could i run them at higher voltages such as +- 45v as long as i dont exceed the 50v rating of the caps? thanks
#2 |
Well if anyone is interested i decided to just try it, the amp was junk anyway. Im uploading a youtube video if anyone is interested. Car amp on ac power - YouTube
#3 |
If you were going to try to get the amps working normally, I would be willing to help but I don't help with any mains powered equipment.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#4 |
Well i got one of the amps running on mains. If i can repair the other one for free to make it work normal i would. Theres is no output from the power supply, it does not draw excessive current. The light illuminates when remote is connected,but is very dimly lit without remote being connected. What else can i check? Thanks.
#5 |
Post the DC voltage on all 3 legs of Q660.
#6 |
1: 11.38v 2: 12.03v 3: 12.05 i measured those at R671 and R679 as i did not want to remove the pcb. Is that ok? Edit: with the remote terminal disconecected the voltages are 1:12.05v 2:2.1v 3:12.05v
#7 |
That looks OK.
What is the DC voltage on all 3 legs of Q914 and Q912?
#8 |
Q912 1:12.01v 2:12.05v 3:0v Q914 1:12.01v 2:12.05v 3:0v
Thanks |
#9 |
All of the power supply FETs have failed.
#10 |
ok, so would just putting in exact replacements fix it? or could something else also have failed? I have a couple of extra Irf3205, could i use two of them for testing purposes? Thanks Edit: also is ebay a good place to order replacements? or will they be fakes?
| Car Audio to Home Theater Conversion Question(s) | WaylandC | Everything Else | 2 | 1st July 2012 04:32 AM |
| Integrated Amp repair / conversion | no idea | Solid State | 4 | 18th December 2011 06:12 PM |
| Convert a home amp (110v) to car amp (12v) | jimmyvstc | Car Audio | 4 | 12th February 2009 05:16 AM |
| Car and Home Speaker Conversion | dirtymexican | Multi-Way | 8 | 17th May 2006 03:33 AM |
| Home theater & Car Stereo .. | TVP | Swap Meet | 4 | 12th January 2005 08:03 PM |
