Car amp repair and home amp conversion.
Old 19th December 2012, 05:15 PM   #11
Perry Babin is offline Perry Babin  United States
If you know FOR A FACT that the eBay seller is legit, you can buy from them. If you do not, buy from a reputable distributor like Digi-Key or Mouser.
The drivers and gate resistors may have failed. You need to remove the FETs and check the gate resistors to see if they have all opened.
Do not install any FETs until you know that the drive circuit has been repaired and is working perfectly.
Old 19th December 2012, 05:39 PM   #12
ivoh is offline ivoh
Ok thanks, all the resistors come up as 47 ohms. How would i check the drivers? Digikey has IRFZ44NPBF-ND and IRFZ44NPBF, which do i need? Thanks. Also regarding the one of these amps i plan to run on mains (its too beat up to fix properly IMO) would you help me trouble shoot the L Ch output section? Thanks
Old 19th December 2012, 06:43 PM   #13
Actually instead of repairing the L ch i will just remove it, what jumpers or transistors do i need to remove to cut the power to it? thanks
Old 19th December 2012, 07:01 PM   #14
You need to remove and test Q903 and 904. They are almost certainly defective. You should also remove and check Q909 and Q910. Click the basic transistor testing link in the sig line below, use the applet for testing BJTs and post screen caps of the readings you get.
If the output transistors are shorted, remove them. If they are not, you can leave them in the circuit.
Old 19th December 2012, 07:48 PM   #15
ok thanks. I will have to do this sometime next week most likely as i will be away till then.
Old 30th December 2012, 08:44 PM   #16
Just to update i replaced all the mofsets and it all worked fine. Apparently nothing else besides the mofsets had fried. Thanks for the help.
Car amp repair and home amp conversion.Hide this!Advertise here!
Car Audio to Home Theater Conversion Question(s) WaylandC Everything Else 2 1st July 2012 05:32 AM
Integrated Amp repair / conversion no idea Solid State 4 18th December 2011 07:12 PM
Convert a home amp (110v) to car amp (12v) jimmyvstc Car Audio 4 12th February 2009 06:16 AM
Car and Home Speaker Conversion dirtymexican Multi-Way 8 17th May 2006 04:33 AM
Home theater & Car Stereo .. TVP Swap Meet 4 12th January 2005 09:03 PM
Copyright ©1999-2017 diyAudio
