Hifonics Zues XI
Hifonics Zues XI
Old 3rd January 2013, 06:39 AM   #11
seankane is offline seankane  United States
seankane's Avatar
Pins 9 and 10 do not have a square wave on them.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 3rd January 2013, 07:18 AM   #12
Perry Babin is offline Perry Babin  United States
Post the DC voltage on all pins of the IC.
Old 3rd January 2013, 07:40 PM   #13
seankane's Avatar
As I was testing pin #8 on the 494 something on the back of the driver board smoked.
There is 2 transistors Q81 and Q82. The say CY 210 on them, any ideas of what they are?
The amp does not power up now. It does nothing like its totally dead.
Old 3rd January 2013, 09:06 PM   #14
Possibly a KTC4373.
I think they are QB1 and QB2.
Old 4th January 2013, 05:22 AM   #15
seankane's Avatar
Wonder if I could sub the 2SD1898's I have.
Same pin configuration, both npn.
Collector-base current: little lower 100v/vs/120v
Collector-emitter current: little lower 80v/vs/120v
Emitter-base current: same
Collector current: higher
Collector power dissapation: higher
Junction temp: same
What do you think?
Old 4th January 2013, 05:38 AM   #16
They would probably work but I don't know how they're being used in the circuit so be careful when powering up the amp.
Old 4th January 2013, 05:48 AM   #17
seankane's Avatar
OK well they must do alot because if they have failed everything to the 494 is dead. The amp does nothing, totally dead. I am going to remove them and check them out.
Wierd thing is, as soon as I metered pin #8 on the 494 the back of the driver board smoked and everything went dead instantly, no current draw no nothing. Its like somebody just turned a light switch off.
Old 4th January 2013, 05:54 AM   #18
seankane's Avatar
Here is a front and back pick of the pwm board. You can see the 2 transistors on the back of the board. This is a pretty old amp.
Old 4th January 2013, 06:09 AM   #19
Are you getting B+ and remote voltage to the driver board? Look at the attached image if you can't read them on your board.
Old 4th January 2013, 06:16 AM   #20
seankane's Avatar
No I am not, maybe I should be checking QP10,11,12???
Hifonics Zues XIHide this!Advertise here!
Hifonics zues series 1 power supply dajones Class D 6 22nd November 2010 12:11 AM
Hifonics Colossus xi and Zues xi georgetownent Solid State 0 26th August 2010 02:45 AM
Hifonics hercules xi mike49504 Car Audio 12 9th January 2010 06:59 PM
hifonics VIII zues and gemeni anthonyc213 Parts 1 9th April 2009 01:42 AM
hifonics zeus xi mike49504 Car Audio 68 12th February 2009 05:23 PM
