I have a kicker kx850.2 and kx350.4 and both worked fine one day but the next they just wouldn't turn on at all. So I tested all my wiring and it was fine. I took out the amps and tested them in four other cars and they still would not turn on. They just kept on blowing the fuses and thats all that happened. Opened up and nothing looks blown or burnt and everything seems fine. Any sugestions?
#2 |
Did they blow the fuse before remote voltage was applied?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
The fuses blew after I turn on my radio. All you hear is a pop and then nothing and then smoke from the fuses (on the 350.4 its 2 20 amp fuses and on the 850.2 its 3 40 amp fuses)
#4 |
That's generally due to shorted output transistors.
#5 |
Am I able to change the transistors myself? I know a lot about car audio and how to diagnose amps. If so, what transistors do I use?
#6 |
If you're new to repairing amplifiers, you should read the basic amp repair page (link in sig line below). Read all of it, even the parts that you feel are irrelevant. If you still have questions, let us know.
#7 |
I know a lot of stuff about amp repair etc and I am an expert at soldering. What transistors do I use to replace the ones in there now?
#8 |
You'll use exact replacements.
#9 |
ok i went to radio shack and bought the same transistors (matched up the numbers) and changed them. It worked fine for about an hour and then same thing happening now. Except now the fuses are blowing before I put in the remote wire. What do i do???
#10 |
What were the part numbers on the original transistors that you replaced?
| Kicker Kx 500.2 Amp. | Desafinado | Car Audio | 29 | 29th December 2012 08:31 PM |
| Kicker KX 600.4 amp | 404Amps | Car Audio | 3 | 14th December 2012 08:23 AM |
| kx kicker 1500 | timwebb | Car Audio | 14 | 22nd October 2012 07:36 AM |
| Kicker Amp Kx 600.4 Not Kicking | MYLEY | Car Audio | 0 | 17th February 2006 03:11 PM |
| Kicker: KX vs. SX | NaftaliG | Car Audio | 0 | 11th December 2004 08:21 PM |
