#11 |
The caps are the silver metal cans. They are notorious for causing problems but they look clean on the preamp board. You can see it better so you'll have to determine if there is any corrosion.
The same caps can cause problems throughout the amp and to make the amp reliable, long term, you may have to replace all of them if any have begun to leak. The resistor is part of the feedback circuit. Is the one on the other side (R133) similarly discolored? If you touch the fluid on the board with your soldering iron and it smells like anti-freeze (or some say it smells like fish), it's electrolyte and the cap near it will need to be replaced. You'll need to clean the residue with solvent (acetone works best but alcohol will also work). Dive a 100Hz signal into the amp and measure the AC voltage on pins 8, 12, 17 and 18 of the preamp board. Post the voltages. Have the gains set the same for both channels. Set the input level from the signal source so that you read at least 0.1v AC on pins 8 and 12. Place the black probe on the RCA shield when taking the readings.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#12 |
Thanks Perry, can I swap the caps for regular ones or do the need to be exactly the same?
Also how do I determine the values? I might just change them all |
#13 |
They are generally all 10uf@16v. You can use standard caps but there's no point. The hardest part is getting the old SMD caps off of the board without damaging the pads. Replacing them is very easy (on the main board, it's more difficult on the preamp board because they're so close together). If there is no corrosion on the preamp board, I'd leave them alone for now.
Post the voltages.
#14 |
#15 |
Well those were your power supply fets. You might have shorted outputs.
You need to replace the 2 power supply fets, the power supply fet gate resistors, and the power supply drivers. Test the output fets and make sure they are not shorted. Your first priority now is to get the supply up and running, you can do no further testing until the amp will power up.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#16 |
R2 and R3 are the gate resistors.
I'd replace them with 47 ohm resistors and use IRF3205s as replacements. Power up the amp and measure the DC voltage on the ends of R2 and R3 farthest away from the FETs. What voltage do you read?
#17 |
Thank you gents, I'll give it a go and message back,
one thing I think that could have caused this is, I sprayed some wd40 into 2 screw clamp holes as they were tight, maybe it caused a short? |
#18 |
WD-40 won't cause any problems at the low voltage that's being used in car amps.
#19 |
Ok I replaced the 3205's and the resistors, I also pulled q203 and q206 both are defective
I powered it back up and it works, So any idea what q203 and q206 replacements are? Thanks |
#20 |
I generally use IRF540s for replacements. Check R118 and R126.
| Rockford Punch 60x2 DSM | Dr Zeus | Car Audio | 31 | 22nd January 2013 07:40 AM |
| Rockford fosgate punch 40 repair help | chipper | Car Audio | 10 | 17th September 2012 11:10 PM |
| Punch 40 DSM | seankane | Car Audio | 36 | 21st November 2011 04:11 PM |
| punch 40 dsm | bdgf2004 | Car Audio | 10 | 11th January 2011 12:03 AM |
| Rockford punch 100 dsm | mike49504 | Car Audio | 1 | 13th December 2009 12:41 AM |
