no name amp - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th December 2012, 04:54 PM   #1
timwebb is offline timwebb  United States
Default no name amp
im working on a few of these Chinese made amps im looking for the output drivers on this card. or seeing if anyone know a similar board.
Old 9th December 2012, 05:41 PM   #2
Are they not the six transistors on each end, just like the DWM3640 that has 8 per side.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 9th December 2012, 06:23 PM   #3
yea but the number sanded off.
Old 9th December 2012, 06:31 PM   #4
I stated the wrong board, D1820 driver board uses transistors marked DK and AC.
Check the 470 ohm resistors, all of them usually are out of tolerance.
Old 9th December 2012, 06:33 PM   #5
thanks here is the amp...all i can find on it.
Monoblock High Power Class D Amplifier By Ronfa Electronic, China
Old 10th December 2012, 01:50 AM   #6
ok on another board the same amp. the amp is dead all i have is the gate voltage in the power supply. i think the 494 is bad.
Old 10th December 2012, 02:13 AM   #7
Do you have the square wave on the gate or DC voltage?
What are the other pins doing?
Old 10th December 2012, 02:28 AM   #8
no there is no wave on at the gate. here's the pins.
0.0
0.0
0.0
.0.4
0.0
0.0
0.0
12.72
0.0
0.0
12.73
12.70
0.0
0.0
0.0
0.0
Old 10th December 2012, 02:53 AM   #9
the amp dont have a name
Old 10th December 2012, 03:08 AM   #10
Compare it to the following board.
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 03:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
Copyright 1999-2017 diyAudio
