Hifonics Brutus BXi1208D Hifonics Brutus BXi1208D - diyAudio
Old 6th December 2012, 03:59 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Hifonics Brutus BXi1208D
Hello recieved this amp for repair, it powers up and does not draw any current and seems stable. It will produce audio for a few seconds then goes into protect.
I checked the output terminals for for DC and the amp starts at 0 vdc when first powered, the DC steadily rises to -3.578 vdc then the protect kicks in, then the DC slowly discharges back to 0 vdc.
One of the rail caps was a little swollen but had not vented, they are 4700uf 63v and all I have is 4700uf 80v. I replaced the one as you will notice in the pics, should I replace the other to match or does it matter?
Could this be the transistors on the audio board marked 1d and 2d as the culprit?
pic1: the board
pic2: audio driver board
pic3: pwm board
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 6th December 2012, 04:45 AM   #2
Perry Babin is offline Perry Babin  United States
The caps don't have to match.
Yes. I'd expect the 2 1D transistors to be the fault.
Old 6th December 2012, 05:08 AM   #3
seankane's Avatar
OK I changed them all going to re-install driver board.
That CHIPQUIK sure works amazing, thanks for the heads up on that.
Old 6th December 2012, 06:03 AM   #4
seankane's Avatar
Now the amp will not power on, there is no current draw but it drops my supply down to 5 vdc.
Old 6th December 2012, 06:05 AM   #5
evianamp2011 is offline evianamp2011  United States
evianamp2011's Avatar
Just a thought , static?
Old 6th December 2012, 06:13 AM   #6
I don't know how your supply works but none of mine will drop to that voltage unless they're loaded beyond their current rating.
Insert a low value current limiting resistor (2 ohm would be OK but a 1 ohm may be better) in the B+ line to see if it still draws the voltage down.
Old 6th December 2012, 06:15 AM   #7
seankane's Avatar
I removed the new rail cap I installed and now the amp will power up? I think I put it in backwards by mistake. What a rookie move.
BRB
Old 6th December 2012, 06:18 AM   #8
seankane's Avatar
It looks to have been in right, maybe it is shorted.
Old 6th December 2012, 06:18 AM   #9
Look at the silkscreen. The negative terminal will be marked. According to the cap orientation in similar amps, it looks right in the photo.
Old 6th December 2012, 06:31 AM   #10
seankane's Avatar
I thought the grounds of the rail caps would be directly connected to each other. The only marking I see is a big arrow.
I hook power to the replacement cap out of the circuit and it charges and holds a charge.
If I install it in the same orientation as the other cap it wont power on.
Does the positive of one cap connect to the negative of the other?
Hifonics Brutus BXi1208DHide this!Advertise here!
Hifonics Brutus bxi2000 ultra Car Audio 20 27th June 2012 07:09 PM
Hifonics Brutus BX1605D mike49504 Car Audio 3 25th July 2011 05:12 AM
Hifonics Brutus lee1976 Car Audio 3 20th July 2010 11:19 AM
Distored Hifonics BXI1208D, nothing blown? UG0TB4NN3D Car Audio 2 10th November 2009 04:04 AM
hifonics brutus bxi1206d ray9043 Car Audio 2 30th March 2008 05:36 AM
Copyright ©1999-2017 diyAudio
