Go Back   Home > Forums > General Interest > Car Audio
Old 3rd February 2013, 04:06 PM   #31
Default remy tail;
Perry,
Sorry for the delay in getting back with you. Turns out after replacing the FETs and replacing all the components of the 4 drive circuits it powered up and played perfectly. Thanks for all your help...
Now, for the next one.. I have another T40001BD that someone else repaired and they're work is somewhat questionable. I first opened the unit up and diode check the outputs and the powersupply chips. Everything seems fine. So i powered up the amp and everything is fine. No protect light until about 10 seconds. Amp meter on powersupply is around 1-3 amps and then jumps to 10amps. Nervously, i power down and check for hotspots. Nothing obvious, I power up again and check output voltages. I read 110v on half the outputs and then the unit goes into protect. I remove power and remove the +hv, gnd, -hv from the output board and power up. Unit stays out of protect mode now but i seem to have higher voltages from the previous amp. I am reading 184v from +hv and -hv. Does this seem normal or high? I was expecting around 120 or 110V.
Old 4th February 2013, 03:03 AM   #32
Copy and paste this into a new thread.
Old 4th February 2013, 04:30 PM   #33
new thread created.
Rockford Fosgate 4.6x repair help Jan Mattfolk Car Audio 1 23rd November 2012 09:24 PM
What is a rockford fosgate amp t40001bd amp worth? SpinMonster Swap Meet 1 23rd July 2012 04:26 AM
Rockford fosgate deck! Anyone repair these? chipper Car Audio 5 24th June 2012 01:53 PM
rockford fosgate t40001bd bdgf2004 Class D 5 28th October 2010 06:01 AM
Rockford Fosgate P800.2 [Repair] woutzor Car Audio 94 29th May 2010 04:30 AM
Page generated in 0.22588 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
