[Problem] Sinus Live SLA-1500 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd December 2012, 04:36 PM   #1
guifort is offline guifort  France
Question [Solved] Sinus Live SLA-1500
Hello
For start i have read the similar threads like Sinuslive SLA-1500 repair
But i think it's not the same problem.
I have reconnect the amp after 1/2months without utilization.
After powerup a blop sound appear on output and smoke come from amp.
When I open it , on of capacitor have exploded (I haven't capacitor for try to replace it at this time) (The 2nd capacitor side of the red cable)
The U5 and U4 is suspect but I don't know how to test it.
I have attached some photo of the amps. (On extern host because the file is to big)
Thanks in advance
Guifort
Old 2nd December 2012, 08:43 PM   #2
Have you checked the output transistors to see if any have failed?
The rail caps fail regularly on these amps. If there are no shorted outputs...
Remove the blown cap. It will work with that cap missing
Make sure that you don't have any solder bridges between the pads
Clamp all transistors down tightly to the heatsink
Insert a 15 amp fuse in the B+ line and power the amp up.
Does the amp power up without blowing the fuse?
If so, does it produce clean audio?
Old 3rd December 2012, 03:54 PM   #3
Thanks I will try that.
Old 3rd December 2012, 07:03 PM   #4
It work perfect without the default capacitor, I have add a 80W lamp for limit the current and it 's work !
Where can i find this capacitor ? I'am in french.
Guifort
Old 3rd December 2012, 09:55 PM   #5
That's something that you're going to have to buy from a local distributor (Farnell?). The ELH478M080AS3AA capacitor seems to be a sub but I don't know if anyone in France would have it. Farnell has the SLPX472M080H3P3. It's a bit shorter and relatively expensive.
Old 4th December 2012, 08:09 AM   #6
Hello,
I have found at a french store the ECS2ABW222MT6P23040.
It's a 2200uf / 100V,
I hope it will work fine.
Old 4th December 2012, 05:02 PM   #7
It's about 1/2 the value of the original. It may work reliably but the two capacitors on that rail won't share the load equally which could cause one to fail.
Old 4th December 2012, 05:43 PM   #8
Original value is 2200uF 80V @ 105C not 4700 on this amp
But capacitor is in parralel mode like :
CAP1 // CAP2 --- CAP3 //CAP4
If I have right the total capacitor is egal to : 2200+2200/2 = 2200uF 160V
Old 4th December 2012, 05:57 PM   #9
Two 2200uF caps in parallel is 4400uF. The voltage rating doesn't change for the parallel pair.
Old 4th December 2012, 06:43 PM   #10
Yes but the caps in parrallel and in series
I will replace the 2 caps the blown cap and the caps in parralel with it (2X2200uf)
sinus live sla-1500 repair need help Ground Zero Car Audio 46 30th March 2016 03:13 PM
Sinuslive SLA-1500 repair Mote Car Audio 9 5th December 2011 06:45 AM
Problem with Live sound wiggie2gone PA Systems 22 25th October 2011 04:36 PM
Sinus Live SL A - 1500 wont power up mekaiver Car Audio 4 20th July 2011 04:44 PM
Sinus Live SL-A3000 markusb2 Car Audio 1 28th August 2010 09:01 PM
Copyright 1999-2017 diyAudio
