#11 |
Its a DC spike.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator |
#12 |
If you have DC, that's why the relays aren't engaging. The problem is likely on the driver board but you should confirm that all regulators are producing the correct output voltage and that those voltages are reaching the driver board pins.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 |
Sometimes the relay pulses on then off.
I don't see the -15VDC on any pins of the driver card. The regulator is working, just nothing ohms out to the module. The ext2000D schematic doesn't map the module pins correctly.
#14 |
No -15v. See attached.
#15 |
Voltages seem fine with the driver card removed. The two fets that tie to U5 pin 12 seem to fail constantly. I get no oscillation on the gates of any output fets.
#16 |
Are the FETs failing before the amp ever produces oscillation?
#17 |
Correct, I see no oscillation and the fet(s) fail.
#18 |
That would tend to indicate that there is an open circuit between that pin and the FETs that's letting the gate voltage float. The connection could be intermittent.
#19 |
All gates are driven to the negative rail with no oscillation. I should note those fets fail when I have the protection circuit removed, D206. Otherwise the amp will go straight into protect.
#20 |
If you remove all of the FETs driven by U5, does the amp power up and produce audio?
| Need output driver card info for Hifonics Cyclops | Deadly Sones | Car Audio | 2 | 19th October 2011 10:29 PM |
| Hifonics XX Chaos | mike49504 | Car Audio | 1 | 3rd September 2011 05:08 AM |
| Hifonics XX Chaos | mike49504 | Car Audio | 35 | 23rd July 2011 06:06 AM |
| hifonics hurcules xx | mike49504 | Car Audio | 8 | 1st February 2009 11:56 PM |
| hifonics colossus xx | mike49504 | Car Audio | 7 | 28th November 2008 11:15 PM |
